| Literati914 |
May 21 2026, 04:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,319 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
My '73 has an issue where only one of the multiple gauge lights are working. The other ones are holding bulbs that look pretty good, with in-tact filaments. Those bulbs also work when I switch them to that one working light fixture as a test.
When I pull the bulbs from the non-working fixtures, I can get a test light to light up - so there is juice getting to those fixtures through the wiring. I tried using the hole/ground for the good/working light to try and get the non-ones to work there but they did not light there either. What's most likely the issue? |
May 21 2026, 05:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,574 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Those spring loaded light sockets suck. I have had problems with good contact from them. Not sure how to make them function better.
Lo-Fi Version | Time is now: 21st May 2026 - 07:21 PM |
