> New engine arrived. I had to make changes.
cgnj
post May 18 2026, 09:43 PM
It was beautiful out of the box. Put it on the engine stand to install my CFR headers. Those billet stroker push rod tubes are awesome if you're running stock HEs. I was going to put my CFR headers on and the stub tubes for 2 & 4 didn't fit. They are wider than stock. and interfere with the stub tubes. I have a set of AL pushrod tubes from EMS. I put them on and can run with my headers.
There was no way I was going to run HE's and a Triad when the heads were in the box.
DRPHIL914
post May 19 2026, 06:38 AM
Dr. Phil
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
what are the specs of the motor??
VaccaRabite
post May 19 2026, 09:34 AM
En Garde!
So much missing.
Where are the pics?!
Whose engine did you get?
What are the stats?
Why are you teasing us with this?
Zach
post May 19 2026, 09:37 AM
(IMG:style_emoticons/default/popcorn[1].gif) more info please….
cgnj
post May 19 2026, 03:44 PM
Pictures this evening. Chris called me back and we talked about order of operations to get the header assembled. As soon as its on ill post a pic. I didn't get the motor to the shop till 1-2, uncrated, inventory and put on the stand. Then found the pushrod tube problem and fixed that. I'm old that was enough.
I bought this motor 2258 motor in a box. It went to Jorge and was machined balanced. Heads are 42x38 ported. It's set up for 8.7:1.
Time to go back to work before I run out of juice.
cgnj
- Lo-Fi Version Time is now: 19th May 2026 - 05:28 PM
