| L-Jet914 |
May 12 2026, 11:49 PM
Member ![]() ![]() Group: Members Posts: 394 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Good evening fellow Teeners. I have a question regarding the thermostat cable. How does the thermostat cable thread into the thermostat? I was looking at replacement cables and it doesn't look like it has a threaded section to the cable. I started to disassemble the underside to replace my push rod tube seals and perform a valve adjustment. I know I need to replace my thermostat which I just found out today had failed after lord knows how long (still has the VW logo and part number). I tried to remove the thermostat cable from the old thermostat and it snapped off inside which I am not surprised due to the age of the vehicle. Thank you in advance. (IMG:style_emoticons/default/smile.gif)
May 13 2026, 03:32 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,686 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It’s just a bicycle derailleur cable. The clamp is on the flaps.
Lo-Fi Version | Time is now: 13th May 2026 - 11:13 AM |
