> Where to make the cut on a clutch tube repair?
Tdskip
post Apr 30 2026, 01:14 PM
So as some of you may remember, I’ve been battling a shifting issue that I diagnosed as an improperly rebuilt transmission so I bought a replacement one from Bruce (that had been rebuilt by our very own Dr Evil) I’m having the same issues getting gears with the engine running. New coupler, bushings good, shifter adjusted properly, clutch linkage not bent etc…
So that means my inability to get gears is most likely the clutch tube flopping around. It appears I need to open up the tunnel and I wanted to ask if where my finger is pointing is the right spot to make a cut?
Thanks!
post Apr 30 2026, 01:18 PM
No pics, but I took out a whole section about 3" x 10" for general repairs. When done I will simply tack in back in
JeffBowlsby
post Apr 30 2026, 01:35 PM
STRONGLY recommend that you remove the shifter, and/or open the forward tunnel access panel to inspect actual conditions. Using a mirror and flashlight, or better a borescope, look for the issue. Inspect the front tube and middle tube brackets, and also the rear firewall below the engine bay.
Make a conclusion only after inspection, then deciding on the repair(s) can be discussed.
Tdskip
post Apr 30 2026, 01:45 PM
QUOTE(JeffBowlsby @ Apr 30 2026, 02:35 PM) *
Good coaching Jeff, thanks.
@930cabman - The area is all structural so opening up a good size working space isn’t the end of the world, that’s a good tip too.
dr914@autoatlanta.com
post Apr 30 2026, 02:02 PM
there is a diagram in the appendix of the tech tips 700
Tdskip
post Apr 30 2026, 02:16 PM
QUOTE(dr914@autoatlanta.com @ Apr 30 2026, 03:02 PM) *
Sorry but I am not familiar with that resource, where is it located?
Thanks for the post.
barefoot
post Apr 30 2026, 03:44 PM
here's where I cut open to get access to the front bracket,
enlarged the opening between 2 round ports ;
BTW I just used a clamp intended for electrical conduit, took a little blacksmithing
to get correct curvature (a 3/8 extension was perfect anvil) then 1/4" bolt, no welding
Barefoot
- Lo-Fi Version Time is now: 30th April 2026 - 08:21 PM
