> WTB dead MSD box with plug connector, Looking for a way to plug into an MSD harness
worn
post Apr 21 2026, 10:33 AM
I know this is a bit strange, but I want to be able to easily switch out my MSD Digital 6A with a spare 6AL box. The digital unit has a nice plug that makes it easy to disconnect it from the harness for replacement. I have an old non-digital box with the same wires, but it cannot be plugged into a socket - you have to connect each wire one by one. The fantasy is to wire the old box to the kind of connector found on a new box. That way if I have a failure I can make a quick switch and go along my way.
An even better solution would be to source the plug itself, but I haven't had any luck with that.
p.s. it is for the 911, but I hope you will help anyway.
- Lo-Fi Version Time is now: 22nd April 2026 - 07:39 PM
