> *Update* Distributor - 1970 914-6 all stock, UPDATE - WOW, what a difference a Spring makes!
ctc911ctc
post Apr 13 2026, 10:47 AM
***Go to the end for the UPDATE***
Hi all you teeners
My car's idle sticks at 2k if I turn it off and start it immediately it goes back to 950.
Looking for a vendor to fix this - I of course rebuilt it when the engine was out. I am sure all was done correctly (IMG:style_emoticons/default/confused24.gif) I believe that the wrong springs may have been in the rebuild kit.
Is there a vendor that rebuilds and calibrates these?
Thank you Teeners!
CTC911CTC
post Apr 13 2026, 11:10 AM
Wrong springs will not make a dizzy sticky and hold at a given rpm.
Check your sliding advance plate within the dizzy.
Check your carb linkage
DennisV
post Apr 13 2026, 11:45 AM
QUOTE(ctc911ctc @ Apr 13 2026, 09:47 AM) *
Hi all you teeners
Thank you Teeners!
CTC911CTC
Which distributor do you have? Marelli or Bosch? I sent our Marelli S112BX distributor to Ed Fall Vintage Werks LLC . He tested and sent me a curve mapping. He can also make adjustments to the advance progression as needed.
post Apr 13 2026, 12:44 PM
I might first watch the timing marks and see if they correspond (advancing) with the engine speed.
Also, double check you carb synch
post Apr 13 2026, 01:02 PM
Sparx Werks
fiacra
post Apr 13 2026, 01:06 PM
Second vote for Bill at SparxWerks. He has done two distributors for me so far. His work is excellent.
I had the same symptoms you describe, was told it was the distributor sticking, only to find out later that there was a kink in the accelerator cable. Not saying that is the cause of your problem, but something to put on the list to check.
porschetub
post Apr 14 2026, 07:59 PM
QUOTE(Superhawk996 @ Apr 14 2026, 05:10 AM) *
(IMG:style_emoticons/default/agree.gif) it can only be the advance weights not returning ,wrong springs will only effect when and how the advance comes in, my Marelli was I bit gummed up so give it a good clean and fine ,these are very simple units and robust ,but I remember Clay mentioned they can hang up on the advance stops ,hopefully he will chime in as appears he knew their issues well ,cheers and good luck .
gms
post Apr 17 2026, 07:35 AM
By stock I assume you are talking about a Marelli Distributor ? ditch that and get a Bosch unit
mskala
post Apr 18 2026, 08:03 AM
R
I have almost 3 of these Marelli units. One was working fine in my car until
engine changes required a bosch S type curve, so they are sitting. You can
check them out and see how the weights move/feel, and test install.
I have to assume that there is something sticky preventing free movement of the
weights. This is very low tech.
Mark S.
post Apr 22 2026, 09:30 PM
(IMG:style_emoticons/default/beer.gif)
ctc911ctc
post Jul 13 2026, 10:25 AM
looks like someone has cornered the market for the 914-4 distros! What a collection, and why are they on the ground - perhaps hallowed ground?
Wait, those are all 6's????!!!!
ctc911ctc
post Jul 13 2026, 11:09 AM
Soooooooooooo
I got this car running - and mechanically it is sound, but I had a great deal of trouble with the carbs and bought a new set - WHICH - I could never get set completely correct, etc.
Hard to start
Hard to set idle
Looked at timing a few times - all good idle and 6K
THEN!!!!!!
The throttle started to stick at 2K. If I turned the ignition off for a second and then turned it back on the car would settle back at ~1K
HHHHHMMMMMmmmmmm
I decided to check the distro,
here are the old and new springs
When I did the rebuild (simplest mechanical device ever) there are just a few parts. The weights are good and the springs seemed OK, HOWEVER.......
The springs I received from the rebuild kit (on the right in the picture) were different - I called them and verified that I received the correct springs........hhhmmm
Yesterday I put in the old springs (on the left, in very good shape) and they held the weights at rest under tension where the new springs from the kit had a bit of slack in the weights......double HHHhhhhmmmm
Put the distro back in the hole, buttoned it up turned the key AND!
The car started instantly, and settled at an idle WHILE cold. This would not happen prior.
Reset the timing at idle and the RPMs rose to 2K. I backed off the idles screws - slowly and watched the car settle at 980ish. Wow.
Drove the car and the power curve is much better, less spitting THOUGH i will need to go through the least-lean method again, running rich but not too rich,
Also, on a down shift too much fuel - had a BIG-BANG in the muffler.....YOW
Moral of the story - vendors have new employees who do things wrong and do not realize it. Check the product if it looks wrong.
I believe all of my carb chasing was a product of this situation where the timing floated a few degrees at low RPMS,,,,,,,,
Will update when I do the least-lean
- Lo-Fi Version Time is now: 13th July 2026 - 10:22 PM
