> sway bar info scan, H and H sway bar instrutions PDF
914Wes
post Apr 11 2026, 07:11 PM
I have seen this online before but could not find the link so here is my copy rescanned. Contains some useful sway bar info:
Attached Image Attached ImageAttached ImageAttached Image
Attached File  h_and_h_914_sway_bar_instrutions.pdf ( 1.13mb ) Number of downloads: 8
post Apr 11 2026, 08:55 PM
(IMG:style_emoticons/default/beerchug.gif) Nice ,,I just found an 18mm front in my pile yesterday.... (IMG:style_emoticons/default/beer.gif)
post Apr 11 2026, 09:42 PM
What is find useful are the formulas to calculate the twisting force.
This helps to know the affect of the change when you have adjustable levers.
I am still working on making 16mm sway bars with adjustable levers to be able to have an effective range of a 15 to 19 mm bar.
We also have a bunch of sway bars ranging from 15 to 22mm with adjustable levers and Heim joint drop links. Bars, levers are restored. Working on restoring drop links and assembling with correct hardware.
seanpaulmc
post Apr 12 2026, 05:48 AM
QUOTE(bdstone914 @ Apr 11 2026, 10:42 PM) *
Bruce,
Do you have bushings for these H&H drop links?
post Apr 12 2026, 05:53 AM
QUOTE(seanpaulmc @ Apr 12 2026, 07:48 AM) *
Bruce,
I have an h&h bar that needed bushings. Another member here made me up a set on his lathe. I think it’s pretty easy.
mate914
post Apr 12 2026, 07:19 AM
Matt
QUOTE(914Wes @ Apr 11 2026, 09:11 PM) *
PDF file does not show the rear sway bar. Somewhere I have the info on paper, but PDF would be great also.
Matt
post Apr 12 2026, 07:45 AM
QUOTE(mate914 @ Apr 12 2026, 06:19 AM) *
Matt
That is all we had. The rear bar installation is pretty straight forward.
We have both fron and rear H & R bars and can show assembly when we get there.
- Lo-Fi Version Time is now: 12th April 2026 - 04:44 PM
