> Speedo boot?, Can it be installed from the rear?
robkammer
post Apr 8 2026, 07:24 AM
Robbo
Teeners, while I had the engine out I had hoped to replace is the speedometer boots at the tranny and firewall. Now I realize that may not be possible without pulling the cable out of the tunnel and dash. Has anyone successfully stretched the boots over the rear fitting?
Robbo
Replies(1 - 1)
rgalla9146
post Apr 8 2026, 08:11 AM
QUOTE(robkammer @ Apr 8 2026, 09:24 AM) *
Robbo
I don't think it's possible even if you did remove the cable.
The 'nut' at the speedometer end is large and the hole in tthe boot is very small.
- Lo-Fi Version Time is now: 8th April 2026 - 12:01 PM
