| TonyA |
Apr 3 2026, 01:39 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 675 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
I had everything working fine before i installed the engine.
Now the small green turn signal light stays on. I removed all the turn signal bulbs and its still on? I moved the hazard switch a bunch of times on and off. any ideas.? |
| Rob-O |
Apr 3 2026, 02:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,313 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
Is the turn signal stalk actuated? It’s a 70’s European vehicle. The turn signal (both front and rear) is designed to stay on when the key is removed and the stalk is actuated for a left turn or a right turn.
| TonyA |
Apr 3 2026, 02:56 PM
Yea i read about that. No it is not on. This is a 1974 early march if that matters
Thanks |
| Spoke |
Apr 3 2026, 07:19 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,371 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Do the turnsignals work left and right?
Do the hazards flash all external turnsignal bulbs? Does the L/R tach indicator flash with the turnsignals? Below is the basic schematic for the 74-76 914 with single L/R tach indicator. The tach indicator is powered by the C/K/C2 pin of the flasher relay. That should only operate with flashers flashing. What other wiring work was done? |
Lo-Fi Version | Time is now: 4th April 2026 - 10:40 AM |
