> Rear ride height question, How can I easily raise it
robkammer
post Mar 29 2026, 07:30 PM
Robbo
Teeners, or Brain Trust if you prefer. While I have the engine out of the BB I would like to address the rear ride height if it’s fairly easy. The Koni’s came with the car, and the rear height is almost an inch lower than I would like it, although the shocks seem to be performing well. To me, it looks like I might be able to add spacers to the lower perch, if I can find some. Or am I not seeing the geometry correctly? If this would work, any idea where I can source the spacers?
RobboAttached Image
bkrantz
post Mar 29 2026, 07:41 PM
It looks like the spring perch is adjustable. If so, the collar around the shock body has grooves and a snap ring that sets the height of the perch section. Move the ring and perch to a higher groove and raise the ride height.
Literati914
post Mar 29 2026, 07:43 PM
Got a picture of the car's stance, as-is ? - I'm just curious where it sits now.
I have some spacers that I just took off of a set of Konis, but the engine is out and so I'm not sure where it's gonna sit or if I'm gonna like it. If I like it without the spacers, I might would part with mine.
Krieger
post Mar 29 2026, 10:56 PM
QUOTE(bkrantz @ Mar 29 2026, 06:41 PM) *
- Lo-Fi Version Time is now: 30th March 2026 - 05:19 AM
