> Does precise lengths of vacuum hoses matter?
s13u74cr4
post Mar 28 2026, 01:47 PM
In the process of wrapping up replacing all the vacuum lines on my 73 2.0. I went by a combination of the 73 and 74 diagrams on Bowlsby’s site. But looking at this one some of the lengths seem long compared to what was in the car and fit without having a bunch left over. The three 36” lengths make no sense to me.
(IMG:https://bowlsby.net/914/Classic/zTN_FI_Hose_Vac_2.0L_1973-Early1974.jpg)
post Mar 28 2026, 01:51 PM
Length doesn’t matter. At least in this case….
fixer34
post Mar 28 2026, 02:15 PM
Length has no effect on the vacuum/air/fuel flow. You want the lines long enough for smooth bends and easy routing.
Like we say with electrical wires; it's easy to make them shorter, not so much making them longer...
If you still have the old ones you can use them as cutting templates.
post Mar 29 2026, 01:24 AM
I like to make vacuum hoses a little longer than original. They go bad at the ends. When they do you can cut off the stretched, hard or cracked part and reuse the hose.
post Mar 29 2026, 04:07 AM
QUOTE(bdstone914 @ Mar 29 2026, 01:24 AM) *
spot on. (IMG:style_emoticons/default/beerchug.gif)
1 Members: Jack Standz
- Lo-Fi Version Time is now: 29th March 2026 - 05:25 AM
