| porschetub |
Mar 26 2026, 10:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,055 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Not really well titled but will proceed with more info ;
Engine hasn't been started for about 1yr due to an unrelated issue that I have only just found out about , so over that period I would expect the sump is holding a fair chunk of the oil tank capacity? ,for that reason the change of these exhaust valve covers will require a sump drain due to flood back from the stock tank ?. Old mag covers are buggered really even after being resurfacing twice,,they have gone soft I had these on and twice and got minimal leakage because the engine had been recently run . I have the covers , VR gaskets and mounting hardware ,thoughts from others would be very helpful ,cheers. |
| Luke M |
Mar 27 2026, 04:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,495 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Not really well titled but will proceed with more info ; Engine hasn't been started for about 1yr due to an unrelated issue that I have only just found out about , so over that period I would expect the sump is holding a fair chunk of the oil tank capacity? ,for that reason the change of these exhaust valve covers will require a sump drain due to flood back from the stock tank ?. Old mag covers are buggered really even after being resurfacing twice,,they have gone soft I had these on and twice and got minimal leakage because the engine had been recently run . I have the covers , VR gaskets and mounting hardware ,thoughts from others would be very helpful ,cheers. I would just drain the entire engine and tank oil. R&R the valve covers/gaskets and refill with new oil and filter. If you're using the turbo lower valve cover they'll need some of the fins milled down. There's a couple of ways to get this done. One would be to have a machine shop shave the fins down a bit or just remove enough of the fins to clear the suspension ear. There's a few threads here that cover this. |
| mlindner |
Mar 27 2026, 05:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,747 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
You can remove plugs and turn engine over a couple 15 sec. and all oil will be back in the tank....but why, as Luke said just drain oil....Its shot.
Lo-Fi Version | Time is now: 27th March 2026 - 08:39 PM |
