> Sealant for oil pickup extension
Fazasport
post Mar 25 2026, 06:29 AM
Rich - What is the recommended sealant for attaching the extension tube to the existing oil pick up tube.
Is there a curing time for the sealant before assembling the remaining tuna can components.
914werke
post Mar 25 2026, 07:13 AM
I use Locktite 515
FlacaProductions
post Mar 25 2026, 08:57 AM
I used Permatex 29132 and let it sit overnight just to be sure.
914werke
post Mar 25 2026, 11:08 AM
.. there is no wrong answer (unless you are using KY lube or something equally ridiculous) the point of the sealant is to ensure any small discrepancy's between the stamped steel pickup tube & the machined steel extension dont leave any gaps. Ive found I often need to "dress" the PU tube with a fine file for fitment
type2man
post Mar 26 2026, 01:12 AM
QUOTE(Fazasport @ Mar 25 2026, 07:29 AM) *
Hondabond. It does not dilute or separate like any permatex product.
DRPHIL914
post Mar 26 2026, 02:27 PM
Dr. Phil
hm, installed mine originally and was on therer for 5 years , didnt use anything, and reinstalled it on my new motor recently as i will be doing some AX and also didnt use anything, so i guess on the next oil change i iwill pull this and reinstall with sealer but i had no idea.....
(IMG:style_emoticons/default/chair.gif)
- Lo-Fi Version Time is now: 27th March 2026 - 08:38 PM
