> Fuel pressure help, 1st start after rebuild
TonyA
post Mar 16 2026, 12:23 PM
Nachmal
Doing the first start on a stock 1974 2.0 FI
I have confirmed spark and some fuel. When i put a little gas down the intake it runs a little. My spray at #2 was weak. I had the pump wired backwards. I fixed that. I put a gauge in line after the fuel rail going to the side port of the regulator. I confirmed getting fuel from the side rail after #1 the hose at the end of the regulator goes to the return across the engine to the side return line. I am getting 42PSI. Is this the correct location for the fuel pressure gauge? Is the plumbing correct fuel rail end at #1 to side port and top end port to the return? With this configuration I tried to lower pressure and I cannot. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
mgphoto
post Mar 16 2026, 01:07 PM
You should be able to reduce the pressure at the fuel pressure regulator which is at the end of the fuel ring. I think it’s 37 lbs.
TonyA
post Mar 16 2026, 01:28 PM
Nachmal
Thanks but is the plumbing correctly routed?
Ron914
post Mar 16 2026, 06:39 PM
QUOTE(TonyA @ Mar 16 2026, 01:23 PM) *
Hello ,
My supply comes in on the passenger side and feeds # 3 & 4 Cyl then crosses over to driver side fuel rail and feeds #2 & 1 Cyl then to the port on the side of fuel pressure regulator then out the bottom back to the return to tank . Fuel pressure should be around 29.3 psi . My car is a 76 2.oL D-Jet Fi
TonyA
post Mar 17 2026, 05:34 AM
Nachmal
thanks....my plumbing is correct then
Dave_Darling
post Mar 17 2026, 07:10 PM
914 Idiot
The pressure gauge should tee into the high-pressure fuel loop somewhere. You don't want to dead-head the high-pressure part to the gauge, you will wind up with very high pressure that you can't change.
Depending on the plumbing in your car, you can run the hose that goes to the cold-start valve to the gauge. AFAIK, the 2.0 cars should have a single fuel hose that goes to the cold start valve. Just unhook that from the valve and hook it to the gauge.
Other years/engine sizes may have two hoses going to the CSV. If that is the case, you can put together a Tee using brass plumbing supplies and swap that Tee in where the CSV is, then run one leg of the Tee to the gauge.
Using the CSV spot as the location for the gauge should mean that the gauge is showing the pressure in the high-pressure loop that feeds the injectors, which is the important pressure that we care about. The high-pressure loop is everything "downstream" of the fuel pump and "upstream" of the fuel pressure regulator.
--DD
TonyA
post Mar 20 2026, 05:35 AM
Nachmal
Thanks. I got it dialed in.
post Mar 20 2026, 06:22 AM
Just in case.... the fuel pressure number you are after is 29.
42 will make your car run so rich you will fill your oil pan with gas and wash the cylinder walls of all lubrication.
- Lo-Fi Version Time is now: 20th March 2026 - 08:24 PM
