> Dipstick Tube Replacement
yeahmag
post Mar 2 2026, 12:21 PM
The dipstick tube is damaged on the case I'm using for my new build. I thought it would be no big deal to replace, but I can't seem to find the right tubing size. Anybody have some guidance?
-Aaron
porschetub
post Mar 2 2026, 05:12 PM
QUOTE(yeahmag @ Mar 3 2026, 07:21 AM) *
-Aaron
I would say in will be metric , but wall thickness will dictate what you can fit in there ,how the hell you get the old on out I have no idea,cheers.
MartyYeoman
post Mar 2 2026, 05:16 PM
I'm interested in seeing how this is resolved as I have a otherwise good case with the same problem. (IMG:style_emoticons/default/headbang.gif)
URY914
post Mar 2 2026, 06:10 PM
I built the lightest 914 in the history of mankind.
I took a Type iV engine out of a VW 411 and it didn't have the dipstick in the same location as a 914 T-4. I drilled a hole where the 914 dipstick needed to be and used a piece of copper tubing that I bought at a hobby shop for the tube. I epoxied it in place with some JB Weld. It lasted for years.
Krieger
post Mar 2 2026, 11:14 PM
I saw a post hear once upon a time where someone fixed that by drilling the remnants out of the case. He then tapped the hole in the case and used a segment of larger brake line threaded into the case.
sdoolin
post Mar 3 2026, 10:15 AM
I used a bus case for my 2056 build, had to manufacture the dipstick tube. I used a section of 5/16" hydraulic brake line. Press fit into a 5/16" hole drilled into the case, then peened and JB welded into place. It has several thousand miles on it and all is well.
zig-n-zag
post Apr 14 2026, 09:11 PM
I recieved the 2 replacement dipstick tubes I ordered from European Motorworks today.
The OD of this stainless tube is 8.5mm verses the stock tube of 8mm, so the hole to mount the tube in the case will need to be opened up a bit.
European Motorworks can do the installation if you like, talk to Jorge.
zig-n-zag
post Sep 14 2026, 04:21 PM
Here’s how I did my dipstick installations.
Put the new tube in the freezer overnight.
Cut off the damaged dipstick tube flush with the case.
Use a 8mmx1.25 tap to create threads and screw in an 8mm stud.
I needed to use a 3” 1/4” drive socket extension with the tap wrench to
clear the chimney.
Knock out the old tube and stud with a long punch and hammer.
Get the new tube from the freezer and with a few hammer raps, it’s done.
There was no need to open up the case tube hole.
- Lo-Fi Version Time is now: 14th September 2026 - 05:21 PM
