> What to do about scratch in Rear Main Seal bore?
frank_c
post Feb 27 2026, 12:38 AM
I'm in the process of replacing a leaking Rear Main Seal, and after pulling the old seal I noticed two scratches in the case bore (honestly, it wasn't me - I have the proper tool for this (IMG:style_emoticons/default/smile.gif)).
From what I've been able to find the RMS should be installed dry, but what is the best practice to address the two scratched areas to avoid a leak? Here are some of the suggestions I found when searching:
1. Use an emery cloth to knock-down any raised edges
2. Fill scratch with high-temp JB Weld
3. Use some type of sealant at the scratch
Do I use none, one, or some combination of the above (or some other) to address this? Any help would be much appreciated as I'd like to get the new seal in this weekend.
rfinegan
post Feb 27 2026, 07:01 AM
2. JB Weld not needed
3. Use favorite sealant at the scratch and around seal
Ninja
post Feb 27 2026, 09:31 AM
Those scratches are completely covered by the OD of the seal.
I might put a bit of 3H (case sealant. your choice) in the big one.
post Feb 27 2026, 10:16 AM
QUOTE(Ninja @ Feb 27 2026, 10:31 AM) *
(IMG:style_emoticons/default/agree.gif) or a shellac based sealant
Jack Standz
post Feb 27 2026, 10:59 AM
For your consideration is getting a GoWesty RMS installation tool. Seems that after all these years of just using a wood block or something to pound in the seal dry, there is a better way.
The instructions include using a sealant when you install the seal and drilling a drain hole back into the case at the bottom of the seal bore. Also, the tool insures the seal ends up properly positioned (make sure there isn't a Grove on the crankshaft which could cause a leak).
https://gowesty.com/blogs/article-library/f...main-seal-story
frank_c
post Feb 27 2026, 01:18 PM
QUOTE(Jack Standz @ Feb 27 2026, 10:59 AM) *
Thanks for the suggestion - I've seen that tool before. It looks great, but my plan was to use a bearing/seal tool to tap in the seal. One question I have though is what is the correct depth of the seal? Should it be flush with the top of the bore in the case? Will the seal be "bottomed out" at that point anyway so it can't go any further?
As you mentioned, the GoWesty site for the RMS itself recommends the use of 'Vibra-TITE 550 Blue Core Plug Sealant' on the seal. This is a bonding sealant similar to Loctite 540. I have not found any other references recommending the use this type of product on a Rear Main Seal. Anyone have any experience with it? Will this make the seal difficult to remove the next time?
And regarding the drilling of a hole to allow for additional oil drainage - I've also read about this modification in the past and it sounds like a good ideal, but a concern I have is aluminum shavings falling into the case during the drilling process on a assembled and sealed case. How do you prevent this from happening?
Ninja
post Feb 27 2026, 01:50 PM
You could mildly pressurize the case (less than 3 PSI).
or
Drill 90% of the hole, clean up, pack drill bit with grease on flukes, finish hole slowly cleaning up the bit as you go.
or
The best way IMO is to do the Raby mod when you have the engine apart later.
Look at your crank to see if there is a score line. I always set my seal depth depending on where this line is. I AVOID this line if I can. You can see the original seal was not bottomed out.
The important area to have as perfect as you can is where the seal hits the crank.
Depth is not important (within reason), being equal depth is (seal straight in bore).
1 Members: porschetub
- Lo-Fi Version Time is now: 27th February 2026 - 02:40 PM
