| wonkipop |
Feb 23 2026, 08:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,419 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
interesting end to the afternoon yesterday.
we decided to roll the TVR out of its corner and start it up to turn the engine. hasn't been started for a couple of years. TVR grantura mk 111. delivered to australia in 1965. think its a 64 build. made in UK. front mid engined layout. fibreglass body bonded to space frame ladder chassis similar to a lotus. original cars ran a variety of 4 cylinder engines. often coventry climax similar to lotus or MGA or MGB engines depending on the years built. this one is a bit unique. later in life in aus fitted with Leyland P76 V8 dating from the 1970s. 4.4 L aluminium engine. derived from the same engine as used in Rover 3500 and in Range Rovers. originally a Buick design that Rover bought from GM in the 1960s. approx 190-200 hp. car weighs 800ib with engine. the engine weighs roughly the same as the heavy old 60s 4 bangers - so handling balance etc theoretically not compromised. started up with no hesitation even after a a couple of years. ran and idled sweet. warmed up to operating temp. looks like might be next spare time workshop project to see if it can be put back on the road. been off the road since 86. could be a bit of a challenge given the body and space frame construction. its tiny. i'm 5 foot 11 and even i can hardly fit in it. |
Feb 23 2026, 08:41 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,471 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
800lbs - ?
kilos? |
| Ninja |
Feb 23 2026, 08:50 PM
Member ![]() ![]() Group: Members Posts: 158 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Over here that was called the BOP V8 Buick/Oldsmobile/Pontiac.
In 62 it was one of the first cars to have a turbo in the Oldsmobile "Jetfire". The turbo also had water/methanol injection from the factory. My dad designed and helped build a Can-Am car that used one of these. It was stroked/bored up to 5.0l and made north of 400hp in the early 70s. The English (Rover I believe) bought the rights to it and put it in a bunch of stuff. Neat little engine! That would be WICKED to drive! |
| bkrantz |
Feb 23 2026, 09:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,608 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Cool. What's the max driver size?
I always felt that Colin Chapman had no use for guys like me (6-2 American, 188 cm). I remember barely squeezing into a Europa, and getting just part of one leg into an Elan. Do TVRs work the same? |
| wonkipop |
Feb 23 2026, 09:41 PM
| wonkipop |
Feb 23 2026, 09:45 PM
Cool. What's the max driver size? I always felt that Colin Chapman had no use for guys like me (6-2 American, 188 cm). I remember barely squeezing into a Europa, and getting just part of one leg into an Elan. Do TVRs work the same? pretty much. i have trouble fitting into a lotus elite and i am not exactly a big person at 5 11 tvr felt just like that. |
| wonkipop |
Feb 24 2026, 01:00 AM
Over here that was called the BOP V8 Buick/Oldsmobile/Pontiac. In 62 it was one of the first cars to have a turbo in the Oldsmobile "Jetfire". The turbo also had water/methanol injection from the factory. My dad designed and helped build a Can-Am car that used one of these. It was stroked/bored up to 5.0l and made north of 400hp in the early 70s. The English (Rover I believe) bought the rights to it and put it in a bunch of stuff. Neat little engine! That would be WICKED to drive! yeah @Ninja when i said handling would not be theoretically compromised by beautiful buick derived V8 (and yes - magnificent engine) i said it with tongue in cheek and sphincter squeezed tight. it could be that chassis is overwhelmed? (IMG:style_emoticons/default/smile.gif) i suspect a delicate right foot might be required given the short wheelbase (but wide) and short squarish foot print. i won't be driving it even if invited - unless its on a skid pan or somewhere you can't hit anything sideways. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) suspect it would be happy to get its tail out and then rotate - probably more than once. however i would not mind working on it. i think its a very interesting little car. |
| Ninja |
Feb 24 2026, 01:30 AM
Wonki, one of my customers has a short wheelbase CJ5 jeep with a 500+ hp 6.2L SRT motor in it.
It's just STUPID! Any throttle application past about 20% just lifts the right front wheel off the ground which makes it handle even WORSE than normal. It's impossible to drive! No fun at all... Your little roller-skate would just spin. It almost looks shorter than a Midget/Sprite! It would probably do well in a burn out contest... |
| Tdskip |
Feb 24 2026, 06:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,753 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
These actually drive quite well and are very nimble and feel surprisingly planted. Very well sorted out handling in my experience.
Keep in mind the Rover V8 didn’t really add any weight compared to there Triumph TR6 engine some of these came with. |
| jd74914 |
Feb 24 2026, 09:31 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,868 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Very cool!
A 2500M is on my short list of cars to own...I think I might sell everything in my garage for one haha |
| Root_Werks |
Feb 24 2026, 10:08 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,893 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Neat little car, thanks for sharing the pictures.
| AZBanks |
Feb 24 2026, 11:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,075 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
There are some great videos of TVRs like that racing at Goodwood. Well sorted examples with a good driver are FAST!!
| Shivers |
Feb 24 2026, 11:55 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,280 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Lo-Fi Version | Time is now: 24th February 2026 - 02:03 PM |
