> CHT Spade Connector Housing
cabrioartie
post Feb 21 2026, 06:48 PM
My mechanic recently replaced my CHT and used electrical tape over the spade connectors which I find unacceptable.
I assume there should be a spade housing covering the connectors like so many other places around the engine.
I've searched, but haven't found the part. Does anyone know if they are still make it (and the part number) or where I can find a similar housing to use?
Literati914
post Feb 21 2026, 07:09 PM
Is this it, second row from the bottom ?
https://www.bugcity.com/shop/shop.lasso?pquery=connector
post Feb 21 2026, 07:17 PM
Yup . . . Lazy mechanic beware. (IMG:style_emoticons/default/chair.gif)
If you want OEM connector place WTB in classified - someone can probably come up with one.
If you’re not hooked into OEM there are parts like this available commercially. Wiringdepot.com, granger, McMaster Carr, etc are likely sources Attached Image
post Feb 21 2026, 07:19 PM
QUOTE(Literati914 @ Feb 21 2026, 09:09 PM) *
This and probably easier to source than my recommendation that may force larger quantity purchase.
cabrioartie
post Feb 21 2026, 08:08 PM
Sorry, I don't know if it's just my car, (but it does look original) but the car's wiring harness end is a male connector and this male spade seems very long too, only the CHT end is a female connector.
So, I would need one of these with a female and male on each end.
JeffBowlsby
post Feb 21 2026, 10:27 PM
Hey Artie, I have just what you need. PM me your address and I’ll get it right out to you.
6 User(s) are reading this topic (4 Guests and 1 Anonymous Users)
1 Members: Lockwodo
- Lo-Fi Version Time is now: 21st February 2026 - 11:05 PM
