| Thunderchief |
Feb 19 2026, 10:34 PM
Member ![]() ![]() Group: Members Posts: 197 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
Most of the time shifting from neutral to 1st at a stop will grind but if I'm still rolling and shift into 1st then its fine. I don't like holding the clutch while waiting for the light to turn though.
What is your best guess to what it might be? Thanks. |
| brant |
Feb 20 2026, 07:37 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,143 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
1st gear slider
Expensive part Very common |
| Chad911sc |
Feb 20 2026, 08:14 AM
Member ![]() ![]() Group: Members Posts: 268 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Mine was doing the exact same thing when I bought my car last year. I thought the transmission needed rebuilt or replaced. After much reading on this site, I thought I would try the tangerine racing shifter set up. I changed the side shift bar and the bearing at the firewall. I also did the console adapter fix at the transmission that gives the shift point more stability. Totally transformed my shifting from grinding into first and very hard to find the gears, into easy to find gears and zero grinding.
If that is your only symptom, Brandt is probably right, he is very knowledgeable. If you’re having other symptoms other than just the first gear issue, check out Tangerine racing. |
| mgphoto |
Feb 20 2026, 01:54 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,403 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Most of the time shifting from neutral to 1st at a stop will grind but if I'm still rolling and shift into 1st then its fine. I don't like holding the clutch while waiting for the light to turn though. What is your best guess to what it might be? Thanks. Check the clutch adjustment, make sure you use the factory procedure and spec. Does it happen in reverse also? |
| flyer86d |
Feb 20 2026, 03:07 PM
Member ![]() ![]() Group: Members Posts: 482 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I’ve always used the trick Fred Apgar taught me. Push in the clutch, select 2nd gear, then pull it into 1st. That uses the 2nd gear synchro to stop the movement in the transmission.
Charlie |
| WizPorsche914 |
Feb 20 2026, 03:09 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region |
Most of the time shifting from neutral to 1st at a stop will grind but if I'm still rolling and shift into 1st then its fine. I don't like holding the clutch while waiting for the light to turn though. What is your best guess to what it might be? Thanks. Check the clutch adjustment, make sure you use the factory procedure and spec. Does it happen in reverse also? Mine does in 1st and reverse ???? |
| Thunderchief |
Feb 20 2026, 05:26 PM
Mine is 1st only
Feb 20 2026, 05:51 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,462 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Check your clutch cable adjustment. If it’s not that, it’s probably a worn dog and slider. Look at the mileage. Over 80k and there’s a good chance some parts will need to be replaced. It’s not a hard and fast number but it’s something to look at.
| L-Jet914 |
Feb 20 2026, 09:16 PM
Member ![]() ![]() Group: Members Posts: 383 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I had a similar issue a few years back now. When I took my transaxle apart to reseal it, I adjusted the shift rod clearances and the 1st/Rev clearances to the middle of the specs in a custom made jig. I no longer experience it as much as I used to. If I am at a long light, I'll leave it in neutral and then slowly pull it into 1st from a stop and it doesn't grind. Most of the time I shift into 1st below 20mph because the stops at the intersections are short. Other times I find myself shifting into 2nd then into 1st out of habit.
| dtmehall |
Feb 20 2026, 09:20 PM
Member ![]() ![]() Group: Members Posts: 247 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
| Spoke |
Feb 20 2026, 11:12 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,343 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I’ve always used the trick Fred Apgar taught me. Push in the clutch, select 2nd gear, then pull it into 1st. That uses the 2nd gear synchro to stop the movement in the transmission. Charlie (IMG:style_emoticons/default/agree.gif) |
| barefoot |
Feb 21 2026, 07:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,479 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Mine will grind into 1st if I engage quickly after clutch depressed, but if wait about 3 sec it goes in smoothly. Often I don't bother with 1st as plenty of torque to start in 2nd.
Never a grind into reverse, so probably 1st synchros wearing out. Also I do NOT sit at a light with clutch depressed. Barefoot |
| 930cabman |
Feb 21 2026, 10:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,504 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I’ve always used the trick Fred Apgar taught me. Push in the clutch, select 2nd gear, then pull it into 1st. That uses the 2nd gear synchro to stop the movement in the transmission. Charlie (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) works for me, also make sure the clutch is correctly adjusted |
| IronHillRestorations |
Feb 21 2026, 06:23 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,916 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Adjust clutch cable, front and back.
Check shift bushings. Check clutch tube at firewall. Check pedal cluster. |
Lo-Fi Version | Time is now: 21st February 2026 - 11:03 PM |
