> Speedo sensor to 915 Gearbox
Biggles
post Feb 17 2026, 01:57 AM
Region Association: England
Hi all.
Curious to know what other people's set up is with their speedo sensor on their cars. I have a 915 gearbox (on a 3.2 engine) and have had to pull the sensor out of the case as the speedo needle was bouncing. (Had the speedo rebuilt and checked the earth to it).
See photos. Obviously not a normal set up given the box is flipped from a 911 and a previous owner has made up something that was working. I haven't cleaned the sensor yet as that may do it but curious to know where this sensor might have come from (it looks like it's been broken out of a larger body/housing) and what others have on their 915 or 901 set up.
Cheers.
Chris Attached Image
Steve
post Feb 17 2026, 09:21 AM
Buy the correct speedo sensor and special side plate for it from Wevo.
That is what I’m using with no issues.
https://www.wevo.com/Products/TransmissionP...nSideCovers.htm
https://www.pelicanparts.com/More_Info/9116...amp;SVSVSI=0586
Biggles
post Feb 18 2026, 06:35 AM
QUOTE(Steve @ Feb 17 2026, 03:21 PM) *
Thanks Steve. Doesn't look a cheap set up!
Anyone else?
@Cairo94507 Michael, whats your set up?
ConeDodger
post Feb 18 2026, 07:18 AM
Apex killer!
QUOTE(Biggles @ Feb 18 2026, 09:35 AM) *
Anyone else?
Chris,
In the UK, you’ll use Twinsparkracing.com I think. I have a 915 with LSD all set up but I seem to have abandoned the plan and stuck with the 901. (IMG:style_emoticons/default/wacko.gif)
T.Rick6
post Feb 18 2026, 07:29 AM
I also had this problem, went with a GPS for my Speedo. I followed Clay’s write up…
post Feb 18 2026, 08:31 AM
Michael
Chris @Biggles - I have a later 911 electric speedometer and I went with Dakota Instruments digital GPS speedometer unit. I have been using it since my car got back on the road about 7 years ago. I hope this helps. (IMG:style_emoticons/default/beerchug.gif)
post Feb 18 2026, 08:50 AM
QUOTE(Cairo94507 @ Feb 18 2026, 09:31 AM) *
Michael - Is that 2 units or 1. I need to get something for my electric speedo but I don't see the second SG1-5E listed. Just the GPS-50-2
@Cairo94507
post Feb 18 2026, 09:33 AM
Michael
Hi Mark @mepstein - Yeah, 2 units. The 2nd one is a speedometer "interface". Dakota Digital said I needed both to make it work. If you need it, I can look for my paperwork. (IMG:style_emoticons/default/beerchug.gif)
post Feb 18 2026, 09:36 AM
QUOTE(Cairo94507 @ Feb 18 2026, 10:33 AM) *
Before you look it up, do you have a stock style speedo or is it electronic?
Steve
post Feb 18 2026, 10:47 AM
@biggles check out the GPS speedometers from speedhut. I’m running this Speedo in my v8 914
https://speedhut.com/gauge-applications/4-g...ometer-160-mph/
post Feb 18 2026, 12:49 PM
Michael
@mepstein - Electronic speedo (later 911).
post Feb 18 2026, 03:51 PM
QUOTE(Cairo94507 @ Feb 18 2026, 01:49 PM) *
Then I guess I’ll need that second unit as well. I couldn’t seem to find it on their website, but I’ll try again. Thank you.
Biggles
post Feb 18 2026, 04:09 PM
thanks all. A few options it would seem. I'm more of an analogue kind of guy so might have to bite the bullet and do the route that Steve suggests....
Larry.Hubby
post Feb 18 2026, 09:35 PM
Member who doesn't post much, but has a long time in 914s
The remains you see on the end of the wires are those of a magnetic reed switch. As the magnets on the disc attached to the differential fly by each triggers a contact closure and the VDO electronic speedometer converts those into speed information. All you really have to do is replace the reed switch and replace the sensor in the hole that the previous owner used to get the reed switch close to the passing magnets inside the transmission case. I have the exact same setup on my car ("78 911SC engine, 916 transmission) only I made an aluminum piece to contain the reed switch, milled a matching hole in the trans differential cover, and cemented it in with Locktite red.
2 Members: Steve, Larry.Hubby
- Lo-Fi Version Time is now: 18th February 2026 - 09:50 PM
