| nmkimosabe |
Feb 16 2026, 11:24 AM
Newbie ![]() Group: Members Posts: 24 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
As a 914 newbie does the entire regulator need to be removed in order to remove the glass or can the forward bolt & plastic block that lifts the window be removed and the window carefully angled to remove it? I need to replace the forward channel guide fuzzy and I don't think it can be done with the window in place.
| Ishley |
Feb 16 2026, 11:59 AM
Member ![]() ![]() Group: Members Posts: 322 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
https://youtu.be/TMQt5OYOdqQ
The glass can be removed without taking the regulator out. There are two different doors… 70-72 and 73-76. The YouTube video is the later… and is an assembly video but should tell you what you need to know. I Always suggest stating the year of the car on a post as there are differences by year. |
| nmkimosabe |
Feb 16 2026, 12:02 PM
https://youtu.be/TMQt5OYOdqQ The glass can be removed without taking the regulator out. There are two different doors… 70-72 and 73-76. The YouTube video is the later… and is an assembly video but should tell you what you need to know. I Always suggest stating the year of the car on a post as there are differences by year. |
| nmkimosabe |
Feb 16 2026, 12:03 PM
Thanks Ed for the suggestion and my car is a 1974 1.8. I will search YouTube for the video.
| nmkimosabe |
Feb 16 2026, 02:11 PM
I watched the video, but it looks like Ian took the regulator and the guides out first and then reinstalled everything including the glass.
| Ishley |
Feb 16 2026, 02:18 PM
Yes but the glass goes in last… so in reverse order you can take the roll up window out and then get to the guide. I assume you’re talking about the rear guide. The front guide is part of the triangle window.
| nmkimosabe |
Feb 16 2026, 02:35 PM
Understood and it's the channel insert that is missing in the front guide that is also supports the vent window. I need to insert a fuzzy in the guide and was hoping not to have to remove the window. Thanks.
| TonyA |
Feb 16 2026, 03:08 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 648 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
Be careful with that front adjusting screw. If I am not mistaken you could turn it to far and dent the door. Guys am I correct on this ?
| nmkimosabe |
Feb 16 2026, 05:29 PM
I could possibly see that happening, but I think I've found the sweet spot on mine and there's plenty of clearance. Appreciate the heads up.
| Ishley |
Feb 16 2026, 09:02 PM
Once you get the window out… you’ll find it might be easiest to just remove the regulator to get the new weather stripping in there. Try to get it in and if it’s too tight pull the regulator.
| barefoot |
Feb 18 2026, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,478 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
I got the old window out using a putty knife to break the seal of the butyl so the window could be released. Then it just lifted out.
Barefoot |
| iankarr |
Feb 18 2026, 06:54 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,591 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
As I recall, you don't need to take the regulator out. You just need to remove the bolts holding the frame to the mechanism. And you'll also need someone to help hold the opening wide so you can get the block out. It's just a bit narrower than the window opening. Good luck!
Lo-Fi Version | Time is now: 18th February 2026 - 09:50 PM |
