> Help and information on EZ36 swap
Ravivos
post Feb 11 2026, 01:14 AM
Hi all,
looking for some information and help, just finished welding my engine cradle for the EZ36 swap, next step is the actual mount of the engine.
the engine is mated to a TY856, a 6 speed transmission (STI) which seems way bigger than the 5 speed that people usually use.
would appreciate any pictures and information on an installed TY856 -
how much was the engine needed to be moved forward to allow the fitment (length wise) of the transmission?
was the rear trunk floor needs to be cut in order to clear the clutch lever, starter and Bellhouse?
if the engine is too low, will it have oil pan ground clearance issues ?
i am too deeply invested in the project, already modified the transmission (converted to 2WD and cut the tail) and dont want to back off now... if i need to cut the trunk's metal sheet, will probably do it, just need to know how much.
also, any reinforcement needed incase of cutting the trunk? i guess i will need to weld some reinforcement between the rear shock towers and the transmission mount...
any information is much appreciated.
Thanks, Raviv.
rick 918-S
post Feb 11 2026, 06:16 AM
Hey nice rack! -Celette
QUOTE(Ravivos @ Feb 11 2026, 01:14 AM) *
Hi all,
Thanks, Raviv.
(IMG:style_emoticons/default/welcome.png) There are several Subi Swaps here. (IMG:style_emoticons/default/assimilate.gif) Someone will see this post and Chime in. Post some photos too! (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Ravivos
post Feb 11 2026, 09:44 AM
some pictures -
This is the engine that i pulled out, its an old SBC with the original trans, i just dont like the V8 sound in the 914, its too heavy and i needed a project (IMG:style_emoticons/default/evilgrin.gif)
this is the engine that goes into the car, EZ36 out of a tribeca with an STI 6 speed transmission.
managed by MS3Pro, did my own wiring, the engine is currently running full sequential, both spark and injection.
engine is running on individual throttle bodies that i designed and 3D printed from high grade engineering material (PPA-CF), designed the idle control as well
transmission 2WD conversion, cut the center diff and welded it so all the torque will be transferred to the front shafts.
tail section was cutted and welded.
Chris914n6
post Feb 11 2026, 12:28 PM
Jackstands are my life.
You're the first I know to use the STi 6 speed because it's, um, too big...
There is a starter that is clocked 'flatter'. I don't remember what year/model it's from, so no cutting trunk floor there.
I'm looking forward to seeing your progress. I'm currently fitting a vq35de in mine, and it's looking like I will 3dp an intake also or hack up the engine lid.
I don't like a 350 in a 914 either (IMG:style_emoticons/default/beerchug.gif)
Ravivos
post Feb 11 2026, 12:45 PM
QUOTE(Chris914n6 @ Feb 11 2026, 08:28 PM) *
Thats a bit concerning, is that really the case? no one ever fitted a TY856 in a 914? the 5 speed is just too delicate for high power applications and the 6 speed STI can take the beating all day long.
but if i have to cut the trunk's floor, i will do it, cant go back now, pfffff.....
rick 918-S
post Feb 11 2026, 04:54 PM
Measure the V8 and 901 tip to tail and measure the Subi and 6 sp. Remember there is still amount 4-6 inches behind the trans mounts with the 901. This space is usually reserved for the muffler. But you may.need it foe the transaxle
post Feb 11 2026, 06:26 PM
The mt5 is almost the same length as a 914 trans. The mt6 is quite a bit longer. I’m sure you can make anything fit but it will be a chore. Probably have to use twin mufflers since there won’t be any room behind the trans without the muffler hanging way off the back.
AZBanks
Cool project. Keep us posted and we need more pictures.
1 Members: tygaboy
- Lo-Fi Version Time is now: 11th February 2026 - 06:55 PM
