| PlantMan |
Feb 9 2026, 02:37 PM
Member ![]() ![]() Group: Members Posts: 456 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I was just telling my son that I knew the clutch cable was going to snap!
On my way home on Friday, it snapped going into 3rd gear! AAA to the rescue! I have 2 cables on the way so I can have a spare in the car with all the connections. Of course, this is not the first time this has happened to me and you would think I would have learned the first time.... Has anyone actually changed theirs on the side of the road before??? Attached image(s)
| Jack Standz |
Feb 9 2026, 03:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 704 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Yes, by driving the left side up onto a high curb. Have also limped home last year in 2nd gear when it broke about 1/2 mile from the house.
Also, fixed a Westfalia bus clutch cable in a Safeway (grocery store if you're not familiar) parking lot on the way to Mexico for a vacation on the beach many years ago. Busses have more ground clearance so not as much a problem, if you have a spare cable. Good plan to have a spare, and a couple 11mm wrenches too (IMG:style_emoticons/default/biggrin.gif) . |
| Geezer914 |
Feb 9 2026, 04:26 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,217 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Replacing the clutch cable in a garage is a PIA let alone on the side of the road! You guys are real troopers! (IMG:style_emoticons/default/smilie_pokal.gif)
Feb 9 2026, 05:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,672 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
If you’re handy with a manual - can be driven home without the clutch. Traffic lights add to the challenge but it’s do-able.
| jim_hoyland |
Feb 9 2026, 05:13 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,016 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
“ Good plan to have a spare, and a couple 11mm wrenches too “ I keep a small bag with two 11mm wrenches, small vice grip, extra nuts, And a loop of bungi cord, and of course disposable gloves and a magnetic flashlight The bungi cord is used to pull up on the clutch pedal inside the cabin |
| mgphoto |
Feb 9 2026, 05:57 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Best is to use the Terry Cable
https://www.pelicanparts.com/More_Info/B423...RxoCjqYQAvD_BwE This cable is double braided it will let you know when it’s going to fail by stretching, a little more costly but you will get home even if half of the strands break. |
| anderssj |
Feb 9 2026, 08:12 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,775 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
Yes, by driving the left side up onto a high curb. Have also limped home last year in 2nd gear when it broke about 1/2 mile from the house. Also, fixed a Westfalia bus clutch cable in a Safeway (grocery store if you're not familiar) parking lot on the way to Mexico for a vacation on the beach many years ago. Busses have more ground clearance so not as much a problem, if you have a spare cable. Good plan to have a spare, and a couple 11mm wrenches too (IMG:style_emoticons/default/biggrin.gif) . (IMG:style_emoticons/default/agree.gif) Fixed mine the same way at the edge of the VAW-124 parking lot in spring of ‘82. LT Bill Klein had a silver ‘73—we fixed his the same way about a week later. Cable breaks must have been contagious. |
Feb 9 2026, 08:54 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,430 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| PlantMan |
Feb 9 2026, 09:30 PM
I pay for the expensive AAA service....might as well get my moneys worth!
Luckily, was 3 miles from the house. |
| mgphoto |
Feb 9 2026, 09:39 PM
| 914rrr |
Feb 10 2026, 11:36 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,024 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) “ Good plan to have a spare, and a couple 11mm wrenches too “ I keep a small bag with two 11mm wrenches, small vice grip, extra nuts, And a loop of bungi cord, and of course disposable gloves and a magnetic flashlight The bungi cord is used to pull up on the clutch pedal inside the cabin 2nd on the extra nuts. They are an odd ball size (7 mm IIRC) and not carried at normal retail or auto parts stores. Ask me how I know... |
| mgphoto |
Feb 10 2026, 11:48 AM
Don’t forget the pivot, that usually falls off with the end of the cable.
| Dave_Darling |
Feb 11 2026, 01:32 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,323 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
2nd on the extra nuts. They are an odd ball size (7 mm IIRC) ... Yes, M7. Taking an 11mm wrench, one of fairly few fasteners of that size on the 914. (Rocker shaft retaining nuts are another.) Don’t forget the pivot, that usually falls off with the end of the cable. It's called a "clevis". The original one was plastic and a bit long; a very common upgrade is a 911 part that is metal but shorter. The latter needs some kind of spacer for the cable, like a short piece of pipe or even a few oversize nuts. --DD |
| barefoot |
Feb 11 2026, 08:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,471 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Whenever I'm stopped in traffic or at a red light I go into neutral & don't rely on the clutch to keep me stopped. The thought of a snapped clutch cable launching me into an intersection concerns me. I've never had an issue but worry about it. (IMG:style_emoticons/default/w00t.gif)
Barefoot |
Feb 11 2026, 09:25 AM
I just keep a spare car in tow. Ya’ never know when you might need a throttle cable, a distributor, a spare CV joint, or a spare transmission . . . (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 11th February 2026 - 06:55 PM |
