| Al Meredith |
Feb 3 2026, 03:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 983 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have the PORSCHE 901 transmission rebuild manual and it tells me to have 15.8 to 20.6 FT LBS drag on the DIF.. I'm reading about 5 FT/LB. with the same diff and case ( no gears installed )There is also very slight visitable and feelable back and forth (left and right) at the CV flanges. Should I install shims ? HELP AL
| mgphoto |
Feb 3 2026, 05:15 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I have the PORSCHE 901 transmission rebuild manual and it tells me to have 15.8 to 20.6 FT LBS drag on the DIF.. I'm reading about 5 FT/LB. with the same diff and case ( no gears installed )There is also very slight visitable and feelable back and forth (left and right) at the CV flanges. Should I install shims ? HELP AL If you are bottoming out the cover and only getting 5 ft lbs there is an issue. Don’t remember o ring out I believe. I think you need the gear stack in to measure the backlash. 914 factory manual is missing some data. |
Lo-Fi Version | Time is now: 3rd February 2026 - 05:58 PM |
