> Volvo brake calipers, How to get caliper to sit in further
Steve1956
post Jan 30 2026, 12:23 PM
Ok,so Ive read a thread on the pros and cons of this. I have the 240 calipers installed and lines hooked up. they rubbed on my Pedrini style wheels so I bought 6mm wheel spacers and that fixed the problem. But recently bought a set Of Fuchs with Vredestein
tires that I want to run. The Fuchs rub the caliper,doubled up the wheel spacer and they still rubbed. Ground some clearance on the caliper frame to no avail. I saw a guy on one of these forums that was making brackets to move the caliper inward. This would solve both problems. Any thoughts?
rick 918-S
post Jan 30 2026, 01:36 PM
Hey nice rack! -Celette
IMHO unless you are increasing the unsprung weight (heavier wheels- larger diameter tires with an increased contact patch) Volvo 4 piston calipers are completely unnecessary. Pull those off and put the stock brakes back on.
yeahmag
post Jan 30 2026, 01:45 PM
Just to put this in perspective. I race with 911 M calipers and good pads. Unless racing with big HP those are unnecessary. If you are racing, you'll find yourself more focused on heat management than the number of pistons.
11 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 30th January 2026 - 02:37 PM
