| Jeff_72 |
Jan 29 2026, 05:58 PM
Newbie ![]() Group: Members Posts: 48 Joined: 15-October 22 From: Texas Member No.: 26,921 Region Association: Southwest Region |
I know that there are a ton of options out there, but seeing the number of these motors that are listed in the Roll Call 914 6 GTs thread, I am wondering if one of you could give me an estimate on what these motors are worth, or what it cost you. Im currently looking at this motor for my Outlaw restomod and the cost im being quoted is comparable to a brand new Honda Civic Si.
If thats correct, then im (IMG:style_emoticons/default/sad.gif) but not deterred. If you have one or similar for sale id be interested in talking. |
Jan 29 2026, 08:06 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,369 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
There’s no one price for what you are asking until you get more specific.
Mag or aluminum case New Mahle p&c’s or refurbished steel Induction-carbs, FI, itb’s Twin plug dizzy or coil on plug. Finding a pre built vs building from scratch vs modifying a running engine Find a running engine - $20 ish Build one - $40-60k Labor is pretty much the same for any engine. Parts aren’t all that different no matter what size engine you build. There’s no way to build an engine cheap. I have about 10 engines in the shop right now and more in the queue. It takes a good 100 + hours to break down, clean, measure, build, etc, etc. Add more hours for tuning and some additional depending on how custom the wire harnesses need to be. So multiple your engine building hourly rate by 100. Add up parts. Add in exhaust, powder coating, plating, refinishing and extras. $$$ |
| Jeff_72 |
Jan 30 2026, 12:47 PM
Thats exactly what I was looking for. I know the options all have a different cost. What I am being quoted is in the range you provided.
For more info, here is what I am looking at. This is a 4 to 6 conversion so I need new Alternator, Pulleys, Fan and Fan Housing PMO Induction Complete 40mm Carb Set Clewett Engineering Crank Fire Complete Kit New Headers |
| dug |
Jan 30 2026, 01:17 PM
914-6 conv in progress ![]() ![]() Group: Members Posts: 185 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
You will spend another $2-5k (or even 10) for fuel and oil plumbing depending on parts choices. The factory put an external oil cooler on the 2.2S and the GTs. Once you spend that much on the engine...
Lo-Fi Version | Time is now: 30th January 2026 - 02:40 PM |
