| alungershausen |
Jan 19 2026, 09:59 PM
Newbie ![]() Group: Members Posts: 1 Joined: 18-October 25 Member No.: 29,037 Region Association: Pacific Northwest |
Hi, first post ever. A friend at C&C told me to reach out. Heard this forum will help.
I bought a 1974 1.8 914 in March of 2025. It is now totally disassembled, and I am struggling with getting the engine taken apart. I cannot remove the cylinder heads, the flywheel does not turn, and the pistons do not move at all. In the last two months I tried, PB Blaster in the cylinders, also filled the case with it. I also filled the case with transmission oil and Marvel Mystery oil. Leaving it sitting for weeks on end, turning it every couple of days. I warmed up the engine with a heat gun, gently tapped the cylinder heads, also tapped the pistons. All with no success. It seems the cylinder heads are glued to the case, not one is moving. The former owner planned to replace the engine with a different one, but I am interested in bringing it back. When I drained the oil, I got about a quart of water (the car was in a field for 4 years) and a little bit of oil. Supposedly it ran 4 years ago. I am planning to attach a lever to the flywheel next, but I don't want to damage the crankshaft. I have not tried a torch yet, not sure if it will damage the case. I am also hearing different places, either the bottom of the cylinders or the case to be warmed up with the torch. The cylinder head insides are pretty rusted and will need to be replaced anyway, but I am hoping that the crank case is still ok. |
| sixnotfour |
Jan 19 2026, 10:05 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,102 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Type4sale
6not4 |
Lo-Fi Version | Time is now: 20th January 2026 - 01:03 AM |
