> Thick oil pump gasket, Pump doesn’t line up
Chad911sc
post Jan 17 2026, 10:26 AM
So my plan was to start assembling the 2056 today, but I found this when placing the oil pump into the case. I measured the gap needed to fill with a gasket, and it’s right at 3mm. Do they make a thick pump to case gasket that will fill this space, so that the rubber sealing ring will be in the case instead of hanging out the back of it??
The gaskets that came with the pump are way to thin to place the pump in the correct position.
fixer34
post Jan 17 2026, 02:30 PM
I don't think you should need a 3mm thick gasket, the paper style is normal.
Either the pump is machined incorrectly or the mounting surface was milled way too much. Hoping it just a bad pump...
Geezer914
post Jan 17 2026, 02:40 PM
Geezer914
Check the clearance to the cam gear with the cam installed.
Montreal914
post Jan 17 2026, 03:03 PM
That groove tawards the inside doesn't look like an O-ring groove, if this is what you are thinking about. (IMG:style_emoticons/default/confused24.gif)
2 Members: Dlee6205, brant
- Lo-Fi Version Time is now: 17th January 2026 - 03:39 PM
