| s13u74cr4 |
Dec 28 2025, 11:57 AM
Newbie ![]() Group: Members Posts: 47 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest |
| windforfun |
Dec 28 2025, 12:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,085 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Hmm... Coaxials?
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) |
| Osnabruck914 |
Dec 28 2025, 12:33 PM
Member ![]() ![]() Group: Members Posts: 192 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
As far as I remember, 8 ohm was pretty standard for automotive speakers back then.
Osnabruck914 |
| DennisV |
Dec 28 2025, 12:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 817 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I thought they were supposed to be 4 OHM at the time. I did some brief research on this. There is some evidence to suggest the early 70s radios are meant to have 8 ohm speakers. Later cars 4 ohms. Thanks to Radiomuseum.org, I found a manual for our specific model 1970 Frankfurt US 7639670. It it indicated 5,8 ohm. The Zenith speakers in the car measure ~6 Ohm. |
| fixer34 |
Dec 28 2025, 02:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,372 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
| chmillman |
Dec 28 2025, 04:03 PM
Member ![]() ![]() Group: Members Posts: 303 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
| s13u74cr4 |
Dec 28 2025, 05:38 PM
These look really close to mine. Do they work? Gonna swap in some new somethings for sure.
Your +/- are the same terminal size no? Mine are not. Here is one of mine, '70 factory -6. Doesn't appear to have ohms noted. Although I have no way of knowing if the radio/speaker was factory or dealer installed. Nothing listed on CoA. |
| s13u74cr4 |
Dec 28 2025, 05:40 PM
| fixer34 |
Dec 28 2025, 09:14 PM
These look really close to mine. Do they work? Gonna swap in some new somethings for sure. Your +/- are the same terminal size no? Mine are not. Here is one of mine, '70 factory -6. Doesn't appear to have ohms noted. Although I have no way of knowing if the radio/speaker was factory or dealer installed. Nothing listed on CoA. I don't have the radio on very much, but both speakers work. Not sure about + or - terminals; they are the same size and been a long time since I traced the wires back to the actual radio, |
| chmillman |
Dec 29 2025, 01:32 AM
These look larger. They fit in the pods? The ones I took out of my 74 2.0 look similar to the above - someone here said they are more or less OEM. No name... Yes, they do. Did - I took them out, in their place is a pair of modern 4x6’s with custom adapters to the OEM housings. |
| s13u74cr4 |
Dec 29 2025, 12:41 PM
These custom adapters, make them or buy them? The originals are an odd size. Photo?
| chmillman |
Dec 29 2025, 03:03 PM
These custom adapters, make them or buy them? The originals are an odd size. Made them. Story here: http://www.914world.com/bbs2/index.php?sho...=371580&hl= Starting at post #4 |
Lo-Fi Version | Time is now: 29th December 2025 - 04:58 PM |
