| Petepat |
Dec 24 2025, 10:01 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
Hi, a simple question (maybe!), can you remove/replace the pushrods on a 1.7L engine without having to take the engine out?
| 930cabman |
Dec 24 2025, 10:07 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,396 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| Jack Standz |
Dec 24 2025, 06:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 635 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Yes. But in some cases you will likely need to remove some pushrod tubes because the pushrod may not clear the chasis (depending on the type of pushrods, like steel versus stock aluminum, etc.).
Dec 24 2025, 07:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,597 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
IMHO the question isn’t can you . . . But should you.
The 914 as is the case with almost all mid-engine vehicles is not designed to have major work done with the engine in the vehicle. Removing push rods is major work. |
| Dave_Darling |
Dec 25 2025, 01:17 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,308 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
You can, and it's not that hard. With some of them, you have to pull the pushrod tube out of the case and tilt the inboard end downward to slide the pushrod out. Those are ones that won't come all the way out because the suspension console is in the way.
--DD |
| Petepat |
Dec 25 2025, 05:26 AM
Hi, a simple question (maybe!), can you remove/replace the pushrods on a 1.7L engine without having to take the engine out? Thanks guys for your feedback, it's very helpful and I ask because my mechanic when adjusting the tappets for me said that he thought one pushrod might be a little bent because he couldn't get the right gap. There also seems to be a clanking noise on starting up which goes after a minute or less, sounds dodgy to me? |
| fixer34 |
Dec 25 2025, 07:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,366 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Not dodgy, but not correct either. I think a pushrod would have to be bent quite a bit to not allow the valve gap to be set. The clanking on startup is a bit more worrisome. By some chance were hydraulic lifters installed in that engine?
| TheCabinetmaker |
Dec 25 2025, 07:35 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,359 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
| Petepat |
Dec 26 2025, 10:55 AM
Thats a very good question, I followed a thread on this site about hydraulic lifters and it sounds very much like the symptoms I have. A simple question (maybe) how can I tell if my engine has HL without taking the engine out?
| Ninja |
Dec 26 2025, 12:48 PM
Member ![]() ![]() Group: Members Posts: 58 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
I don't believe you can without removing at least one push rod and tube.
At that point you can pull the lifter out and inspect. This work CAN be done with the engine installed but is a bunch easier with it out. I did all of my tubes and rods in-chassis as the tube O-rings were trashed and leaking badly. I pulled all of my lifters to inspect for wear/weirdness on both the lifter face and the cam lobe (borescope helps!). I went back with the normal O-rings but later saw a thread on here for improved O-rings which is how I'd go now. Someone found "lobed" O-rings at McMasters. I did completely remove the 75 exhaust system. Others have mentioned that they can be done without exhaust removal. I think having the exhaust in the way would increase the difficulty exponentially. Stupid important to keep all pieces in their original orientation, clocking, and direction. Start mixing stuff up and Mr. Murphy will kick you in the nuts... This job is a BUNCH easier on the stand. As an added benefit (or curse!) you will be able to complete a bunch of other "jobs" that may be needed at the same time. |
| JamesM |
Dec 26 2025, 02:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Yes.
Not much more difficult than a valve adjustment though you do need to remove the heat exchangers. |
Lo-Fi Version | Time is now: 26th December 2025 - 07:55 PM |
