| Literati914 |
Dec 12 2025, 03:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,174 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Anyone know the lengths needed for modern hood struts/shocks for the front ? I would assume that the lbs weight per, spec would be about the same as the rear that I got since the hoods probably weight about the same (I got 60lbs for the rear iirc). But the length is a critical detail that I’m unsure of.
Also wondering about mount placement at the front. Since my rear set have the metal ball joint, I’d like to use the same in the front .. so I was thinking that maybe the stock spring hook multi-mount tab could be utilized with just a simple ball end bolt through it, in the correct size. Anyone done that? General pics of a front set up would be helpful, thanks. Here’s my rear set up: Attached thumbnail(s) |
| dtmehall |
Dec 12 2025, 05:32 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
a little off topic.
where can you get the shocks for the rear hood these days? |
Lo-Fi Version | Time is now: 13th December 2025 - 03:37 PM |
