| SteveL |
Nov 30 2025, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 665 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None
74 1.8 - I previously replaced the 3-port fuel pump with a 2-port pump, mounted to the engine firewall. I have since sent the 3-port pump in for rebuild and have it back.
I have been fighting fueling issues for a long time - fuel pressure drops to 0, engine bogs down/dies. Wait a couple minutes and starts again. I'm down to assuming that there must be a fuel line kink, or a fuel line collapsing somewhere. SO - winter project - All New Fuel Lines. I need some help from the collective brain trust please. Do I: 1: Move fuel pump to frunk by spare tire, stainless lines thru tunnel, new rubber lines everywhere else 2: Leave fuel pump on engine firewall, stainless lines thru tunnel, new rubber lines everywhere else 3: Revert back to stock setup with 3-port pump, stainless lines thru tunnel, new rubber lines everywhere else To complete the above - what do I need to order for the stainless line update, and who is the best to order from? Are they all made by the same person, or are there differences? (and do I need the reducing stainless line from CFR?) Thank you in advance for all the help - Steve |
Lo-Fi Version | Time is now: 1st December 2025 - 02:10 PM |
