> Fire Extinguishers
kenshapiro2002
post Nov 28 2025, 02:29 PM
Anybody use the Rennline seat mount? Not sure where I want to put a fire extinguisher, but this looks like a neat solution without making holes. Any pics of other mounting places appreciated. On my last 914 I just kept it behind my seat!
Ninja
post Nov 28 2025, 02:36 PM
@mb911
I'm using his!
Look here
https://914-6werkshop.com/
mb911
post Nov 28 2025, 03:14 PM
QUOTE(Ninja @ Nov 28 2025, 12:36 PM) *
@mb911
I'm using his!
Look here
I am out of stock and still considering another run or not
Chad911sc
post Nov 29 2025, 01:12 PM
I went with the Element extinguisher. They are are very small footprint, can mount anywhere. Also put out any type of fire without leaving a mess at all. From what they advertise, it last 3 times longer than a typical pull and squeeze type. Even comes with the mounting clip. I measured it and it will fit beautifully under either seat.
kenshapiro2002
post Nov 29 2025, 01:55 PM
QUOTE(Chad911sc @ Nov 29 2025, 02:12 PM) *
Thanks. Just read about it and ordered one. They owe you a commission!
flipb
post Nov 29 2025, 02:38 PM
Pretty critical review/demonstration of the Element here at about 20 minutes in.
https://www.youtube.com/watch?v=WzV07iUE9eQ
Ninja
post Nov 29 2025, 04:28 PM
The only "miracle" fire extinguisher I've seen used was a Halon. I bought one the next day (30years ago). Purple K is similar.
Due to enviromental costs they have gotten expensive and I'm not completely sure it's the same stuff.
This is a possibility I'd look into on Amazon.
https://www.amazon.com/Amerex-Halotron-Exti...4787&sr=8-3
They couldn't completely outlaw them due to the needs of the avaition crowd (I believe) but they wanted to.
Halon is a type of refrigerant...
It displaces the oxygen (big time!) and also goes through a phase change from liquid to gas which absorbs HEAT like a mofo.
I believe that it is by far the best way to put out a gasoline fire hands down.
It's INSTANTANEOUS!
fiacra
post Nov 29 2025, 05:03 PM
Person.Woman.Man.Camera.TV
I read differing opinions/reviews on the Element. What made me decide against it was looking at a car that had a fire and hearing that the Element the previous owner had used to try to put out the fire didn't make a dent in the flames. They used two of them but still ended up losing the fight. It is currently in new hands and undergoing a restoration. I ended up with Ben's FE mount (I actually ended up buying three of them) and a 5lb purple K FE. Ben's mount accommodated the larger FE. I'm not sure 2.5lbs is enough to put out a fire on the verge of becoming fully involved. 5lbs might not do it either, but it gives me a better chance. The heavier FE does cause the mount to "bounce" a bit when driving, but not too much. It doesn't impede on the passenger's leg room. Just a great and economical solution. I hope he decides to make more. Obviously the best strategy is prevention, but you still have to be prepared.
bkrantz
post Nov 29 2025, 09:21 PM
QUOTE(Ninja @ Nov 29 2025, 03:28 PM) *
It's INSTANTANEOUS!
The challenge for Halon is dispersal. It works best in confined or enclosed spaces.
Chad911sc
post Nov 30 2025, 06:24 AM
Sorry if I miss led anyone, I’ve never used the Element before. There is always the hope you never have to use an extinguisher. This is why I went through the entire electrical system when I bought it and also replaced all the fuel lines and connections with a fittings and braided stainless to give me the best chance. The car was a literal ticking time bomb when I bought it for the PO. The people that worked on it for him had moved the battery to the front because of the Hell hole rot, and also put in a new fuel pump. They didn’t even mount the fuel pump to the chassis and it had 5 hose clamps in about a 7 inch space! And the worst part of it all, is they zip tied the fuel lines to the battery cable underneath the Fuel Tank!! (IMG:style_emoticons/default/WTF.gif)
DennisV
post Dec 1 2025, 12:47 PM
QUOTE(fiacra @ Nov 29 2025, 03:03 PM) *
There is a great technical discussion on fire extinguishers on the 356 forum with details from a member who ran a LAB and researched Halon replacements for years. I think you can view even if not a subscriber.
356 forum element fire extinguishers
QUOTE(mb911 @ Nov 28 2025, 01:14 PM) *
Ben. What prevents this from being usable on early cars with fixed passenger seats? I see your description explicitly says: all movable passenger seats
5 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 1st December 2025 - 02:10 PM
