> Front Bumper Top Molding Stud Repair
DennisV
post Nov 27 2025, 09:31 AM
Has anyone had success repairing / replacing a broken stud in the front bumper top molding? One of the studs snapped off during disassembly, despite several soakings in Sea Foam. Best I can tell these are molded into the rubber. I can't think of a way to remove the remaining stud without making things worse. I could of course melt it out, but then I have no way to set a new stud. (IMG:style_emoticons/default/unsure.gif)
I realize new ones are available for sale. This one is in quite good shape with the exception of that stud. Seems a shame to trash it. Especially when the new ones are hundreds of dollars.
IronHillRestorations
post Nov 27 2025, 09:52 AM
I. I. R. C.
You might try drilling it out and tapping it, then epoxy a stud. I’ve seen sheet metal screws used as well.
DennisV
post Nov 27 2025, 10:08 AM
QUOTE(IronHillRestorations @ Nov 27 2025, 07:52 AM) *
I didn't realize you could tap rubber.
Is there an epoxy you've had good luck with? Most of my attempts to bond plastics with any amount of stress applied seem to fail. I see JB Weld has SuperWeld Extreme that claims it will work on rubber.
FlacaProductions
post Nov 27 2025, 10:40 AM
I successfully used JB Weld years ago to place a stud that had pulled out of a rear lower spoiler on a 944 Turbo - very similar material to the 914 bumper tops. I'd try drilling it out, fill the hole with JB and then insert a new stud and let it set up. Just have to pay attention to make sure you have correct alignment and depth.
Artfrombama
post Nov 27 2025, 10:54 AM
Artfrombama
I suggest bonding the rubber to the bumper with panel bond. May require roughing up the chrome under the rubber a bit...
Garland
post Nov 27 2025, 12:30 PM
Restoration Fanatic
QUOTE(FlacaProductions @ Nov 27 2025, 11:40 AM) *
Exactly! J&B
post Nov 27 2025, 12:58 PM
Stud was in a metal washer. Can be drilled and tapped, JB optional if needed.
914rrr
post Dec 17 2025, 05:26 PM
It's been several years, but IIRC, I was able to weld a washer to a suitable bolt and weld it to the internal steel of the bumper top IF the internal steel of the bumper top is solid enough to be welded to.
rgalla9146
post Dec 17 2025, 08:24 PM
QUOTE(914rrr @ Dec 17 2025, 06:26 PM) *
(IMG:style_emoticons/default/agree.gif) Along the same line carefully use a small diameter hole saw to remove rubber around
the remaining part of the stud. Mig a new 6mm stud to hopefully clean metal. Add support with JB weld.
4 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
3 Members: gonzo54, seanpaulmc, Spoke
- Lo-Fi Version Time is now: 18th December 2025 - 08:12 AM
