| Osnabruck914 |
Nov 25 2025, 06:11 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
So, analyzing an annoying vibration coming from the front end of my '74 2.0, proved to be bad inner tie rod bushings on both driver and passenger sides. Shying away from replacing those inner tie rods without a lift, I remembered I had in storage a rebuilt steering rack, complete with inner tie rods, lower steering shaft, hockey puck, and dust cover and decided to replace the whole enchilada.
Naively, I presumed I would just unbolt the outer tie rods, unbolt the steering rack and pop in the new one. No way. I quickly learned that the auxiliary carrier had to be removed first, a piece that is mated to the A-arms, necessitating removal of the torsion bar adjusters and the torsion bars themselves, for clearance. When you are under there, it looks like the aux carrier and the A-arms are one solid piece, but they are not, and must be persuaded to separate from each other with some brute force (hammer and large screw driver). Then, when you think you are home, you find that the brake master cylinder is in the way. Grudgingly, you undo the lines and get the master cylinder out of the way, and in my case buggering up one of the connections, requiring a replacement line be purchased. So, rebuilt steering rack installed, torsion bars and aux carrier back in place, brake system back together and bled, new outer tie rods installed (because my pickle fork tore up the originals).and test drive successful. Car drives straight and true and solid. Vibration gone. The only thing I had to do post test drive was to move the steering wheel one spline to the left to get it exactly centered. All in all, this job seemed harder than removing my engine to do seals, clutch, flywheel, etc. etc., but well worth it. Nobody in my area will touch this car for repairs like this and if they did, they would probably have wanted a boatload of money to do it. One other thing, the manuals out there, including the factory manual are worthless for this job. Osnabruck914 |
| sixnotfour |
Nov 27 2025, 09:47 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,048 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
| rjames |
Nov 28 2025, 12:25 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,409 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
It’s not a small job, that’s for sure. Good on ya for tackling it!
For future reference, you do not have to remove the master cylinder or disconnect any of the brake lines to remove/replace the rack. Also, if you centered the rack and centered the wheel upon installing the rack, you shouldn’t have to move the wheel a spline to center it once everything’s back together. It may just be that the wheel wasn’t centered when you set the toe in. |
| mgp4591 |
Nov 28 2025, 12:53 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,822 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
So, analyzing an annoying vibration coming from the front end of my '74 2.0, proved to be bad inner tie rod bushings on both driver and passenger sides. Shying away from replacing those inner tie rods without a lift, I remembered I had in storage a rebuilt steering rack, complete with inner tie rods, lower steering shaft, hockey puck, and dust cover and decided to replace the whole enchilada. Naively, I presumed I would just unbolt the outer tie rods, unbolt the steering rack and pop in the new one. No way. I quickly learned that the auxiliary carrier had to be removed first, a piece that is mated to the A-arms, necessitating removal of the torsion bar adjusters and the torsion bars themselves, for clearance. When you are under there, it looks like the aux carrier and the A-arms are one solid piece, but they are not, and must be persuaded to separate from each other with some brute force (hammer and large screw driver). Then, when you think you are home, you find that the brake master cylinder is in the way. Grudgingly, you undo the lines and get the master cylinder out of the way, and in my case buggering up one of the connections, requiring a replacement line be purchased. So, rebuilt steering rack installed, torsion bars and aux carrier back in place, brake system back together and bled, new outer tie rods installed (because my pickle fork tore up the originals).and test drive successful. Car drives straight and true and solid. Vibration gone. The only thing I had to do post test drive was to move the steering wheel one spline to the left to get it exactly centered. All in all, this job seemed harder than removing my engine to do seals, clutch, flywheel, etc. etc., but well worth it. Nobody in my area will touch this car for repairs like this and if they did, they would probably have wanted a boatload of money to do it. One other thing, the manuals out there, including the factory manual are worthless for this job. Osnabruck914 Good job! It's not easy but once you're into it, it's logical and it flows rather easily. |
Lo-Fi Version | Time is now: 28th November 2025 - 01:58 PM |
