> Another battery question, Gel?
Flyinlow
post Nov 23 2025, 06:55 PM
Flyinlow
Region Association: Canada
Hi.. what does the brain trust think about gel batteries? Are they the cure for acid spill into hell hole? Are they dependable for the cost?
scallyk9
post Nov 23 2025, 07:01 PM
I put Interstate AGM Group 5 batteries in both of my 914s. Stock looking, they fit perfectly using the stock hold-down plate and were reasonably priced at Costco. Working perfectly at 3 and 4 years old.
post Nov 23 2025, 07:38 PM
Costco:
Flyinlow
post Nov 24 2025, 08:46 AM
Flyinlow
Thank you
mlindner
post Nov 24 2025, 06:02 PM
I went with Optima seven years ago. Very happy. But also moved the battery to the trunk. Best, MarkAttached Image
914werke
post Nov 24 2025, 07:07 PM
QUOTE(jim_hoyland @ Nov 23 2025, 05:38 PM) *
Costco:
Not a bad $
Flyinlow
post Nov 24 2025, 07:42 PM
Flyinlow
QUOTE(mlindner @ Nov 24 2025, 04:02 PM) *
Nice
L-Jet914
post Nov 24 2025, 08:00 PM
I switched to an Optima battery a number of years ago. My 1st yellow top lasted 11yrs before I had to replace it. 2nd one lasted under 2. Now on my 3rd as I warrantied the 2nd one. I may look into Odyssey batteries or now Interstate which I didn't know made AGM flat plate batteries at a decent cost.
Chad911sc
post Nov 25 2025, 11:28 AM
I had the red top Optima in my Jeep when I built it and it did fine until it fully discharged after sitting for several months unattended. After that it never worked again and it was less than a year old. That price on the Interstate is Excellent! Think I found my new battery.
flipb
post Nov 25 2025, 01:14 PM
I've been running an Optima red top for about 14 years at this point. Still works. When I have more than a few weeks of downtime, I hook it up to the Optima branded tender.
Dave_Darling
post Nov 25 2025, 11:33 PM
914 Idiot
Both AGM and gel cells are good for the 914. Not sure if either is a complete fix for the battery acid problems, but they're definitely good to have!
--DD
post Nov 26 2025, 06:35 AM
I had an Optima in my 356 for 19 years, finally gave out
GregAmy
post Nov 26 2025, 08:14 AM
AGM is always a solid option to replace regular "wet" lead-acid. Even moreso if you plan to relocate it. It's fully sealed, and be mounted in any orientation, and will not leak even if the case is punctured.
DC_neun_vierzehn
post Dec 1 2025, 02:23 PM
QUOTE(914werke @ Nov 24 2025, 08:07 PM) *
Costco:
Not a bad $
I cannot find this battery when I search Costo. Actually, I can't find it anywhere when I search on Google, which is strange.
Can you share the Costco link please @914werke ?
Artfrombama
post Dec 1 2025, 03:28 PM
Artfrombama
Also a great replacement in a long hood 911 (x2)
914werke
post Dec 1 2025, 08:21 PM
QUOTE(DC_neun_vierzehn @ Dec 1 2025, 12:23 PM) *
Costco:
Not a bad $
Ya agree I went back & couldnt come up with it either. (IMG:style_emoticons/default/confused24.gif)
There is a item # so you can just call or visit provide the # & they will figure it out.
- Lo-Fi Version Time is now: 2nd December 2025 - 02:26 PM
