> 16x6 wheels what size tires
rick 918-S
post Nov 23 2025, 06:46 PM
Hey nice rack! -Celette
I need to buy tires for my 6. I have a set of 16x6 Fuch wheels. What size tires are you guys running.
Replies(1 - 12)
v82go
post Nov 23 2025, 07:44 PM
Resident Contrarian
Hi
I used 205/55r16’s when I was using 16x6’s.
Bob
Krieger
post Nov 23 2025, 11:44 PM
I've used both 205/55 and 205/50. With a stock geared Trans 55 is definitely better on the freeway. 50 series for the autocross.
rick 918-S
post Nov 24 2025, 05:32 AM
Thanks, I definitely don't want it to look like it has roller skate wheels on it.
post Nov 24 2025, 10:37 AM
195/65x16 slightly narrower
Root_Werks
post Nov 24 2025, 12:41 PM
Village Idiot
QUOTE(v82go @ Nov 23 2025, 05:44 PM) *
Hi
Bob
Stick with the stock size tires. No rubbing or mods needed, they just fit.
Spoke
post Nov 24 2025, 12:44 PM
Jerry
Chris914n6
post Nov 24 2025, 12:56 PM
Jackstands are my life.
205/55 is stock Boxster. tons of tire options. fills in the wheel well.
Beach914
post Nov 24 2025, 01:07 PM
16x6’s with 205/55-16 Kumho’s
Mitox
post Nov 24 2025, 02:20 PM
This website will help size anything.
https://tiresize.com/calculator/
DRPHIL914
post Nov 24 2025, 03:30 PM
Dr. Phil
ive been running 205/55-16 on my front 6" and the rear 7" rims, t is the stock diameter for your speedo, but like others, im putting the 205/50 on my other rims for AX,
the 55's will give a bit better ride , and mine do rub slightly so i put some 1/2" spacers up front to keep them from rubbing on the full turn .
Phil
Dave_Darling
post Nov 25 2025, 12:39 AM
914 Idiot
It can be difficult to fit 205s under the stock fenders with Fuchs. Since this is a Six, I'm guessing it has the earlier type fender lips which are wider than the later ones. And I'm guessing you don't want to modify the fenders or fender lips. Which makes it more of a challenge.
The problem will be in one rear wheel well or the other; these cars are usually not quite symmetrical.
Going narrower makes it easier to fit. Going with 195-width tires (195/60-16 would have near-stock rolling radius) will probably be easier. I don't know if there are reasonable 185/70-16 tires out there, but those would also be close to stock diameter and would be even less likely to cause issues with the fenders.
Of course, if the car is flared then all of this is completely irrelevant.
--DD
rick 918-S
post Dec 28 2025, 05:28 AM
QUOTE(Dave_Darling @ Nov 25 2025, 12:39 AM) *
--DD
Thanks Dave. I am actually un-pulling the quarter panels. So there's that... (IMG:style_emoticons/default/screwy.gif) I know, not what most guys are doing these days. I an acutally leaving the warts on too.
1 Members: emerygt350
- Lo-Fi Version Time is now: 28th December 2025 - 09:47 AM
