| kenshapiro2002 |
Nov 20 2025, 12:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach?
Attached thumbnail(s) |
| barefoot |
Nov 20 2025, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,434 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach? Should be a tab on the back of the horn button. |
| kenshapiro2002 |
Nov 20 2025, 01:14 PM
So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach? Should be a tab on the back of the horn button. Yep… found it. Now I know why it was taped up… horn works fine… ALL THE TIME!!! It’s hot. Hopefully just the relay? |
| Garland |
Nov 20 2025, 01:20 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,418 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach? Should be a tab on the back of the horn button. Yep… found it. Now I know why it was taped up… horn works fine… ALL THE TIME!!! It’s hot. Hopefully just the relay? You’re grounding the circuit when that wire makes contact with the wheel, when depressing the horn pad. There should be a male tab on the back of the horn pad, to connect the wire to. Many of the tabs are broken off. |
| dr914@autoatlanta.com |
Nov 20 2025, 02:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,217 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the lead does NOT go through the hole in the steering wheel!!
something is grounding
| kenshapiro2002 |
Nov 20 2025, 04:13 PM
something is grounding Relay didn’t help. Yeah… gotta find where it’s grounding damnit. So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach? Should be a tab on the back of the horn button. Yep… found it. Now I know why it was taped up… horn works fine… ALL THE TIME!!! It’s hot. Hopefully just the relay? |
| kenshapiro2002 |
Nov 20 2025, 05:00 PM
I’m wondering if it’s at all because the PO installed a 911 horn button on the 914 wheel.
| kenshapiro2002 |
Nov 20 2025, 05:18 PM
I’m wondering if it’s at all because the PO installed a 911 horn button on the 914 wheel. Attached thumbnail(s) |
| bdstone914 |
Nov 20 2025, 07:48 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,186 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach? Should be a tab on the back of the horn button. Yep… found it. Now I know why it was taped up… horn works fine… ALL THE TIME!!! It’s hot. Hopefully just the relay? Swap the horn relay with a headlight motor relay and see what happens. |
| kenshapiro2002 |
Nov 20 2025, 09:54 PM
| L-Jet914 |
Nov 21 2025, 01:02 AM
Member ![]() ![]() Group: Members Posts: 367 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Position 2 is the factory location. The tab that connects to the female connector is broken. I've never seen the horn wire in position one. Position 2 grounds when the button/horn pad is depressed. I think where it is currently it is always grounding causing your horn to sound all the time.
| chmillman |
Nov 21 2025, 01:26 AM
Member ![]() ![]() Group: Members Posts: 224 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Position 2 is the factory location. The tab that connects to the female connector is broken. I've never seen the horn wire in position one. Position 2 grounds when the button/horn pad is depressed. I think where it is currently it is always grounding causing your horn to sound all the time. (IMG:style_emoticons/default/agree.gif) |
| kenshapiro2002 |
Nov 21 2025, 07:58 AM
Position 2 is the factory location. The tab that connects to the female connector is broken. I've never seen the horn wire in position one. Position 2 grounds when the button/horn pad is depressed. I think where it is currently it is always grounding causing your horn to sound all the time. Thanks. |
Lo-Fi Version | Time is now: 21st November 2025 - 02:09 PM |
