2 Pages V  1 2 >
> Rebuilt 3.0 engine issue, Update:Hi temps on one side
scrz914
post Oct 27 2025, 11:04 AM
I have a recently rebuilt flat six engine that I’m going to install in my 914. I built a run stand so that I could do the initial break in and then address any other issues. Start up went well with the expected popping through the Weber IDAs and some backfires through the exhaust. Once warm it ran better. One of the first checks I did was to make sure all plugs were firing by using a temperature gun directed at the exhaust coming off each cylinder. This is where I discovered a huge disparity between the two banks. One side, 1,2,3 cylinders had readings over 500 degrees whereas 4,5,6 was a little over 100 degrees.
My first check was fuel pressure. 3 psi on both sides which is good.
Then I sprayed brake cleaner around the manifolds. Good.
When I sprayed points on the throttle shaft on 1,2,3 there was a noticeable change in idle. It became smoother and increased a little.
My question: could a vacuum leak at the throttle shaft account for the high exhaust temperature? If so, what are my options?
I don’t have much carburetor experience so any expert advice would be appreciated.
Thanks all.
gereed75
post Oct 27 2025, 11:24 AM
That seems like a huge disparity on an engine that is running even reasonably well
Be sure that you are measuring both sides at exactly the same distance from the cylinder head on both sides. EGT drops quickly in relation to distance from the cylinder head.
Beyond that, the first thing I would check is carb float levels. High float levels on the cold cylinders will prevent any fuel from entering the carbs once the engine is running.
scrz914
post Oct 27 2025, 11:38 AM
QUOTE(gereed75 @ Oct 27 2025, 10:24 AM) *
Interesting, I didn’t know that. I’ll check the float levels next.
Regarding the temperature readings, i did use a 6 inch distance on all exhaust pipes.
scrz914
post Oct 27 2025, 01:24 PM
Here’s a pic of my setup. MSD 6AL ignition.
post Oct 27 2025, 02:01 PM
Truthfully it should be titled "low temps on one side"....
It's a complete mess, no hope. I will recycle it for you.
post Oct 27 2025, 02:34 PM
yes, it appears to point to the carb, but seems odd all three on one bank
VaccaRabite
post Oct 27 2025, 02:35 PM
En Garde!
Have you gone through the whole carb adjustment process?
Set best lean idle for each bore?
I suspect you will find that the hot side is the side running the engine, and the cold side is just along for the ride.
You need to take time to get a solid baseline for the idle speed and mix screws on each carb, let the engine get warm and then got find best lean idle. You will want a snail or some sort of carb balancing device to make sure each carb is drawing the same. This is also why your carbs are popping and backfiring - they are imbalanced.
This is all standard first start stuff and nothing to be overly concerned about.
Also GOOD ON YOU for taking the time to get this set on a run in stand. It makes all the balancing SO MUCH EASIER then reaching into the engine bay.
Zach
scrz914
post Oct 27 2025, 03:22 PM
It did seem to me that both sides could be extreme. 100 degrees on exhaust ports seemed low.
As far as the carb settings, I adjusted mixture screws 4 half turns out and idle screws 5 half turns in. Bypass adjustment screws all the way in.
I probably should make sure there is spark on 4,5,6.
mb911
post Oct 27 2025, 03:35 PM
Cam timing is always my go too in this situation
fixer34
post Oct 27 2025, 03:41 PM
QUOTE(scrz914 @ Oct 27 2025, 04:22 PM) *
Is it possible you don't have the plug wires connected correctly/right order on the 4-5-6 bank? With a standard distributor setup it would be near impossible to have 1-2-3 working fine and 4-5-6 not getting spark. Or the cam timing on that side is way off.
scrz914
post Oct 27 2025, 03:50 PM
QUOTE(fixer34 @ Oct 27 2025, 02:41 PM) *
I don’t want to get ahead of myself but would a bad MSD unit cause one bank to not get spark?
post Oct 27 2025, 04:30 PM
QUOTE(scrz914 @ Oct 27 2025, 03:50 PM) *
seems unlikely
scrz914
post Oct 27 2025, 04:33 PM
Always good to check the basics. I DID have 4 and 5 reversed. (IMG:style_emoticons/default/wacko.gif) BUT, I think I did that after I started troubleshooting the temp disparity. We’ll see tomorrow if I can make some progress. I’ll let you know.
Luke M
post Oct 27 2025, 05:43 PM
A far reach but did you install all of the cooling tins for the cylinders and behind the alt?
post Oct 27 2025, 05:53 PM
TDC #1 valves loose, #4 valves tight.. is what you should have..
Cam timing.. right side is prob. loose at the wrong time ..
Root_Werks
post Oct 27 2025, 05:59 PM
Village Idiot
QUOTE(sixnotfour @ Oct 27 2025, 04:53 PM) *
I'm not an engine builder but recognize the symptoms.
brant
post Oct 27 2025, 06:05 PM
Agree with jeff and all
Not working one bank
Spark
Fuel
Timing
scrz914
post Oct 27 2025, 06:06 PM
QUOTE(Luke M @ Oct 27 2025, 04:43 PM) *
Yes. Those were installed by the builder.
scrz914
post Oct 27 2025, 06:23 PM
Man, I hope the engine builder knew how to adjust valves and cam timing. That wouldn’t bode well for the overall build if he didn’t.
post Oct 27 2025, 06:33 PM
turn engine TDC #1 ...hold right carb, wide open, Should blow back at you 100%...Likewise left carb, wide open, Air should bypass some and able to near at tailpipe...
Cams correctly timed in theory..
If both blow back 100%,, the 456 cam is out of time..
2 Pages V  1 2 >
- Lo-Fi Version Time is now: 21st November 2025 - 02:09 PM
