| DennisV |
Oct 22 2025, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 972 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Has anyone had success repairing the hardboard that is behind the seat back pads? I think it's melamine, but it could be some other fiber board or hardboard like MDF.
I have a a couple screw holes that have pulled through, and one side of the interior light clip is pulled out. Most of what I'm finding online seems geared towards thicker furniture applications. ![]() P.S. Perhaps of interest to the originality folks, what appears to be a hand written marking. I think it reads "165". |
| JeffBowlsby |
Oct 23 2025, 07:27 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,268 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Its just a formed wood fiber fiberboard. You can try a fiberglass patch to good material beyond the holes.
| DRPHIL914 |
Oct 23 2025, 07:50 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,944 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
or a replacement panel i believe 914 rubber makes them in hard plastic, you can remove your material and foam and reuse them on the new backer for all panels.
| Root_Werks |
Oct 23 2025, 10:30 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,998 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
If you're looking to keep the original and repair, already been said fiberglass works well with some matting. Soaks into the cardboard.
My 914 already had a 3 piece fiberglass backpad. Thought that was cool, no idea who would have made such a product or when? -Dan |
| TonyA |
Oct 23 2025, 10:41 AM
Nachmal ![]() ![]() ![]() Group: Members Posts: 705 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
I painted mine with a few coats of clear poly after doing some fiberglass repairs. Also painted some clear epoxy on in spots.
Oct 23 2025, 10:54 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,765 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If you're looking to keep the original and repair, already been said fiberglass works well with some matting. Soaks into the cardboard. My 914 already had a 3 piece fiberglass backpad. Thought that was cool, no idea who would have made such a product or when? -Dan 914rubber used to do fiberglass |
| 914sgofast2 |
Oct 23 2025, 12:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I think 914Rubber has now started making them in a plastic material that allows you to staple the upholstery to the backboard, instead of glueing the upholstery pieces to it.
| DennisV |
Jun 11 2026, 01:00 PM
Its just a formed wood fiber fiberboard. You can try a fiberglass patch to good material beyond the holes. Thanks for the fiberglass suggestions. I did some poking around, but most fiberglass videos seem to be for boats or flat surfaces. Didn't scare up much for molded / contoured fiberboard, so I made a short video with help from my dad. There ended up being a few different repairs needed. Not very elegant, but I learned a lot and it should be functionally sound. Maybe it will help someone else down the road. Molded Fiberboard Seat Back Repair with Fiberglass (IMG:style_emoticons/default/type.gif) |
| 914werke |
Jun 11 2026, 06:06 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,680 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Is this just a black center section ?
How about just replacing it |
Lo-Fi Version | Time is now: 12th June 2026 - 12:34 AM |
