2 Pages V  1 2 >
> The engine cuts out above 4,000 rpm when being pushed hard
shag
post Sep 12 2025, 08:42 PM
When the engine is just cruising along and I am in no hurry the car runs fine. When I have the accelerator floored and am taking the engine to the maximum rpm's it begins to cut out at approximately 4,000 rpm. This had happened twice before and I changed the fuel filter, which was extremely clogged, and that fixed the problem. This past winter I removed the fuel tank and had it cleaned out and coated with some kind of reddish substance that seemed great. When I replaced the fuel tank I installed a tubular screen about 4 inches long inside the tank, a new fuel filter between the fuel tank and the fuel pump and replaced the original fuel filter which is near the right rear wheel. I thought I had done more than enough to prevent this from happening again especially since I am preparing the car for Octeenerfest. Wrong again! The car started cutting out again at high rpm's just like before. This time I took the car to Derrick Sweger, who worked for Steve Lindell for many years and has rightfully inherited his business, though is not operating yet was kind enough to lend me a hand. He replace the filter near the rear wheel and then he started on the front filter. The filter on the front was a style that has the clear plastic body around the paper like insides and it looked like it did when I installed it. It was the fuel line that had a sharp bend in it that we thought was causing the problem. Derrick had a 90 degree piece of tubing that took care of the problem. He told me to call him with the results. Approximitely 3 miles down the road I floored the pedal and the exact same problem prevailed. So now I would like to certainly have this fixed before Octeenerfest. What do you guys think is the problem?
cgnj
post Sep 12 2025, 11:54 PM
I think the problem is that you didn't provide enough information to get a meaningful answer. I think a good start woold be telling us if the car is FI or carbed. If FI is it l-jet or d-jet.
mate914
post Sep 13 2025, 05:31 AM
Matt
I’m pretty sure shag‘s car is a 2.0 FI stock
shag
post Sep 13 2025, 02:26 PM
Sorry gentlemen, Matt is correct. The engine is a 1973 2.0 with stock FI. I talked with a couple of guys this morning at the swap meet at Ski Round Top who could only think that it might be the fuel pump. I know a few years ago Bob Hill and I installed a fuel pressure indicator on the car and took it for a drive and at that time it was ok. We are going to check that again. Another gentleman suggested the MPS may be faulty? I don't know how to check one but I believe Bob does.
post Sep 13 2025, 02:48 PM
Doubtful on the mps.
Original dizzy?
GregAmy
post Sep 13 2025, 03:20 PM
Is it throttle position related or RPM?
Is it breaking ignition wise or total car power? Is the tach fluctuating during this? Fuel pressure is a good check to see if it's flat-lining and not keeping up (pump? fuel pressure regulator?)
TPS?
Disty needs oiling?
Needz moar info
post Sep 13 2025, 05:23 PM
QUOTE(GregAmy @ Sep 13 2025, 03:20 PM) *
TPS?
Disty needs oiling?
Needz moar info
I am suspecting stuck weights if it isn't fuel. No advance.
Dave_Darling
post Sep 13 2025, 09:49 PM
914 Idiot
Not sure a lack of advance would cause the engine to cut out, though.
I wonder if it feels like a rev-limiter cut, where the engine will rev and cut several times per second if you keep the throttle floored? Or if the power just drops to where the doesn't want to accelerate much?
--DD
shag
post Sep 14 2025, 01:08 PM
I would like to thank you for your replies. My reply to your replies is:
Emery: My distributor was change out with ( I believe ) what is called an electronic distributor years ago. All I really know is that there are no points, condenser etc. The engine has preformed very well through the years with it.
I am not familiar with term "stuck weights". If you could explain what that means I would appreciate it.
GregAmy: I don't think the problem is with the throttle or RPM it happens only when the engine is floored from about 2,000 RPM. I (currently) am not sure but I don't think the tachometer is doing anything crazy. But I will certainly check. I need to check the fuel pressure. To do that I have to wait for my friend Bob, who owns a guage, to help.
Dave Darling: I am not sure but it seems to me that it is a lack of fuel causing the engine to cut out? I will certainly let you all know when this is fixed.
Meanwhile if you have any suggestions they would certainly be appreciated.
Thanks to all,
John
post Sep 14 2025, 01:37 PM
I wonder if you have a 123 or some other kind of distributor. If it is 123 there are no weights. On a mechanical distributor weights get thrown out through centrifugal force and that advanced your timing. Without that advance your engine can do something like it seems might be happening.
This only occurs under load?
shag
post Sep 14 2025, 05:26 PM
Emery, It is not a 123, but it is a type that doesn't have the old points and condenser. I have never had any problem with it for the last in the last 10 years so that could be it! I will check it out tomorrow. the only problem is that it is a distributor and all I am familiar with are the old type. I am not sure what I will be looking for but I've got to start somewhere.
post Sep 14 2025, 05:45 PM
Does it have vacuum advance? A can attached to it?
GregAmy
post Sep 14 2025, 06:09 PM
QUOTE(shag @ Sep 14 2025, 02:08 PM) *
Sounds like you have a Pertronix (or similar) electronic points insert in the distributor.
The stock disty has internal mechanical weights that swing out as RPM rises, advancing the ignition timing. If these weights get stuck (light rust) and do not advance, then the car feels like it's not making power. It doesn't "cut out" like an ignition miss it just won't accelerate as you'd expect it to.
A widely overlooked maintenance item to avoid this is to lightly oil the weights. To do this, you'll remove the distributor cap and rotor and drop into the rotor shaft a couple drops of light oil, like 3-in-1. Even a thin motor oil would do. If you think the weights may be stuck/rusted, then a light penetrating oil such as PB Blaster or WD-40 should free them up and then follow up with some light oil. Don't overdo it, "a little dab'll do ya" (wow, that's an oldie).
The car originally came with a small foam-ish filter in top of the shaft to keep dust and dirt out, but that may be gone. If yours is there you can just drop in the oil on top of it, it'll find its way down. Dipping in a couple drops each year should keep that from happening again.
Try it, see what happens. - GA
shag
post Sep 14 2025, 08:46 PM
Emery: I am not sure but I will find out tomorrow. Thanks for the advice I will let you know.
GregAmy: I will do that tomorrow and you will know then too.
Thanks to both of you, I really appreciate the help.
shag
post Sep 15 2025, 08:21 PM
Gentlemen, this morning I was talking to a friend about the problem I was having with the 914 and I became confident that the problem was with the fuel supply. The problem I am having was identical to the problems I was having with the filters, not getting enough fuel. So I started out removing the cover that shields the fuel pump and master cylinder for the brakes to check out the fuel pump lines.
They all looked good! This is where I thought the problem was. I then turned off the big bright shop light and turned on my little phone light to peer up into the hole where the fuel lines come down from the fuel tank and there it was, a kink in the fuel line just before the filter which was installed when I installed the tank. I ty-wrapped the filter to a bolt to keep it from kinking the line and it worked. Drove the car around for about 45 minutes and it ran great. Parked the car at home had supper then took the 914 for a little drive again and it had problems accelerating again but it was different though. The car was missing but in a different way! I will check it out tomorrow and let you know.
post Sep 16 2025, 05:19 AM
Check for a loose plug wire. Glad to hear you found your problem.
shag
post Sep 16 2025, 01:03 PM
Emery, Yes sir, I just checked the wires and one of them felt a little bit loose so hopefully that will take care of that problem. I will tell you later after it gets driven a little bit. My friend Bob will be here tomorrow and he will help me with all things 914.
GregAmy, Can I oil the distributer if it is not the type you are discribing?
GregAmy
post Sep 16 2025, 01:53 PM
QUOTE(shag @ Sep 16 2025, 02:03 PM) *
Only the stock disty needs that. If yours has Pertronix installed then it's still using mechanical weights and need oil every once in a while. - GA
Dave_Darling
post Sep 16 2025, 04:43 PM
914 Idiot
Post pics and we can probably tell you what kind of distributor you have.
--DD
shag
post Sep 17 2025, 07:46 PM
Gentlemen, Well what a day. Bob Hill came this morning at 8AM and we took the 914 for a spin and it ran great. So we just took care of minor things like the missing nuts from the exhaust headers etc. So we went for a little ride to the auto parts and the car started missing again. Then it got worse. So we into it. The Pretronox ( found out that is what type it is GregAmy ) distributer was pulled and Bob took it apart, I mean all apart. Oiled the main shaft like you said to GregAmy and soldered a broken wire that seemed to me to keep everything grounded. I cleaned everything up while Bob took care of the technical stuff. He then put it all back together quite well. We installed it and tried starting it. It began to run, roughly, we decided to use the timing light to finish the job and that is when it happened. It just wouldn't start again. We tried everything. Finally Bob measured the voltage and it was something like 9 volts? I think it was suppose to be in the thousands. Nevertheless I thought I would just buy a new one. I talked to at least 2 different auto parts stores and they don't carry them and have no idea where I can purchase one. Does anyone know where I can purchase a coil for a 1973 2.0 4cylinder with stock fuel injection and receive it in a day? Or does anyone know a parts store near York/Harrisburg PA that carries one? I am going to check the web pages of the sellers for 914's that I am aware of. By the way what would make the coil go bad at that time?
2 Pages V  1 2 >
- Lo-Fi Version Time is now: 18th September 2025 - 10:22 PM
