> What is a safe vacuum value to test a MPS?, ...aka the value of looking at VW shows for teener stuff!
914rrr
post Sep 7 2025, 07:00 PM
While cruising the swap meet section at a VW Show yesterday, I picked up an in the box NOS 049 MPS. (IMG:style_emoticons/default/dancinnanner.gif)
I did the :suck tongue" test and it passed. I'd like to test it with a pressure / vacuum tester to ensure it holds vacuum. I definitely don't want to overdo it and damage it.
What is a safe vacuum value to test an MPS?
JeffBowlsby
post Sep 7 2025, 08:18 PM
18 in/Hg is used to calibrate.
Mouth suck test is no good, no where near enough pressure. Use a vacuum pump.
914rrr
post Sep 8 2025, 12:42 PM
QUOTE(JeffBowlsby @ Sep 7 2025, 10:18 PM) *
Thanks Jeff!!
914rrr
post Oct 30 2025, 09:02 AM
OK, it passed the vacuum text with flying colors.
What static electrical tests can be performed to check operational condition?
Ron914
post Oct 30 2025, 09:51 AM
QUOTE(914rrr @ Oct 30 2025, 10:02 AM) *
With a volt /ohm meter check the ohm readings for the primary and secondary coils then check each coil to case ground .
The secondary coil should read around 350 ohms between pins 8 &10 and the primary coil should read 90 ohms between pins 7 &15 then check each to case ground there should be no continuity from case to either 7/15 or 8/10
914rrr
post Nov 30 2025, 03:36 PM
QUOTE(Ron914 @ Oct 30 2025, 10:51 AM) *
to each
OK,
8 & 10 = 360 ohms
7 & 15 = 92 ohms
Not sure about how to check the pin to ground continuity. Is it simply touching neg lead to case and pos lead to each pin individually?
Ron914
post Nov 30 2025, 05:44 PM
QUOTE(914rrr @ Nov 30 2025, 04:36 PM) *
to each
OK,
8 & 10 = 360 ohms
7 & 15 = 92 ohms
Check for continuity between each pin and the case of the MPS .If 7,8,10,15 have continuity to the case then the MPS is bad .
914rrr
post Dec 1 2025, 11:05 AM
Thanks! No continuity found between pins and case.
I found a cross reference chart on Dr D-Jet website below.
Q: can an 049 MPS be used on an 8/72 - 4/73 2.0 with the proper combination of ECU and MPS or am I reading the chart wrong?
post Dec 1 2025, 01:07 PM
If you get a matching CHT and ECU for the 049 you should be fine. You would also want to remove the ballast resistor that would be inline with the CHT on a 73.
1 Members: ejm
- Lo-Fi Version Time is now: 1st December 2025 - 02:12 PM
