chmillman |
Member ![]() ![]() Group: Members Posts: 133 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe ![]() ![]() |
Right now the MPS in my car is mounted with some sheet metal screws and old squished rubber grommets. Not at all the original mountings... Didn't see any suppliers for OE-style replacements anywhere near here, so I am looking at re-mounting it on some rubber standoffs like this:
![]() 10mm in diameter, 10mm high, M4 threaded studs (Form "SS"). Three different Shore A hardnesses available, 40, 55 and 70. The same ones without the "necking down" in the middle are also possible: ![]() The idea is to mount the standoffs to the body sheet metal and then be able to easily bolt/unbolt the MPS on the protruding studs with M4 locknuts and flat washers. What do you think? The mounting should be soft enough to damp out vibration but not so soft to allow the thing to shake significantly. |
Ishley |
Member ![]() ![]() Group: Members Posts: 274 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest ![]() ![]() |
McMaster Carr has rubber grommets that will work with the original mounts.
https://www.mcmaster.com/products/rubber-wa...s/grommets-1~~/ |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,247 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
NEW ones are NOT available. Might be able to use new gromet and install metal piece. Might take one to ACE Hardware see what you find.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,133 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Only real downside I have seen with using the stand off mounts is it puts the MPS into the fuel rail. they work but it gets really tight. |
chmillman |
Only real downside I have seen with using the stand off mounts is it puts the MPS into the fuel rail. they work but it gets really tight. Hmm, OK, at 10mm height, I think it will only add 6mm or so over the original mount. I do have a couple of other ideas for a flatter solution if that is indeed too much. The original mounting parts are long gone. |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,037 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
chmillman |
Hi Jeff, There are lots of rubber grommet possibilities here, but since I don't have the original sizes, I don't really know what to order yet. I take it that the openings on the MPS sheet metal support go into the grommet "slits" and the screws bolt through the centers with a metal insert that keeps the grommets from compressing too much? I can probably engineer something like that here, I thought the standoffs above would be an interesting solution allowing a variable amount of flexibility as well as easier mounting. |
FlacaProductions |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,036 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I'm looking for something on this as well. I think a grommet should be easy enough it's just finding an appropriate metal insert. I can't figure out what to call it in order to initiate a search.
chmillman |
I'm looking for something on this as well. I think a grommet should be easy enough it's just finding an appropriate metal insert. I can't figure out what to call it in order to initiate a search. Basically it could just be a bushing that has an OD that is the same as the ID of the grommet and an ID the same as the bolt through it, the height being about the height of the grommet. You might find a good starting point at a local ardware store and modify it to your needs. |
JeffBowlsby |
The original rubber grommet:
OD 16mm ID 9mm 6mm Thick The ID of the metal bushing is 7mm. I think if you look around an acceptable solution can be derived. Attached thumbnail(s) ![]() |
chmillman |
The original rubber grommet: OD 16mm ID 9mm 6mm Thick The ID of the metal bushing is 7mm. I think if you look around an acceptable solution can be derived. Hey Jeff, Thanks for the dimensions and the image! : (IMG:style_emoticons/default/beerchug.gif) The bushings I can fab here - I have a small toolmaker's lathe - so I just have to look around for some grommets that are around that size. Edit - found these in my collection. The one on the left is 16mm OD, the one on the right about 18mm, both around 9mm ID with groove diameter abut 13mm. The groove diameters may not be quite small enough, but probably can be made to work. ![]() |
JeffBowlsby |
Nice Mitch!
The groove diameter of the original is 11mm, it may compress enough to squeeze into the bracket. |
914Sixer |
Went to ACE hardware and went through all the bronze bearings and the grommets in electrical dept, nothing came close. Spent 1/2 hour.
Lo-Fi Version | Time is now: 18th September 2025 - 10:22 PM |
