jfs911 |
Newbie ![]() Group: Members Posts: 9 Joined: 10-February 18 From: Toronto,Canada Member No.: 21,878 Region Association: Canada ![]() |
Need your help,
Drove car out of 10 month storage, idles but no power. 1973 2.0ltr was running fine when stored. Filled gas tank with premium gas before storage. Any advise greatly appreciated. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,777 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Carbs or fuel injection?
Guessing bad gas, especially if carbs. Zach |
Artfrombama |
Member ![]() ![]() Group: Members Posts: 351 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Still have points? .016"
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,351 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
jfs911 |
Original fuel injection,
premium gas. still have points. |
fiacra |
Person.Woman.Man.Camera.TV ![]() ![]() ![]() Group: Members Posts: 602 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California ![]() ![]() |
I feel like we really need a lot more information in order to be helpful. What have you done so far to diagnose it? Does it idle fine but then fall on its a** when you hit the accelerator, or is it rough at idle as well? Is it backfiring, does the exhaust smell like gas, have you pulled a spark plug to see if it is wet? Have you checked timing, fuel pressure, spark, grounds? Have you made sure no rodents have built a nest in the air cleaner? Have you opened the air cleaner and looked?
I guess it boils down to what you are hoping for. Are you completely lost and need a full checklist to run down? A lot can happen to a car that has been sitting for 10 months. The fact that it was running fine when put away is helpful, but as you can see that is no guarantee that it will be running fine when pulled out of storage. Especially if it was stored out back under a blue tarp during a brutal winter (IMG:style_emoticons/default/biggrin.gif) |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,960 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
I feel like we really need a lot more information in order to be helpful. What have you done so far to diagnose it? Does it idle fine but then fall on its a** when you hit the accelerator, or is it rough at idle as well? Is it backfiring, does the exhaust smell like gas, have you pulled a spark plug to see if it is wet? Have you checked timing, fuel pressure, spark, grounds? Have you made sure no rodents have built a nest in the air cleaner? Have you opened the air cleaner and looked? I guess it boils down to what you are hoping for. Are you completely lost and need a full checklist to run down? A lot can happen to a car that has been sitting for 10 months. The fact that it was running fine when put away is helpful, but as you can see that is no guarantee that it will be running fine when pulled out of storage. Especially if it was stored out back under a blue tarp during a brutal winter (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) bad gas usually gets water separation in the tank. you wil be getting backfires. and a lot of hesitation, cutting out. i like the rodent suggestion re the air cleaner. you guys have ethanol in the gasoline no matter what? or am i wrong? full strength gasoline down here is just that. will last a year at least. but ethanol blend stuff (10%) is notorious for going bad relatively quickly. faster than 10 months thats what i have heard. i would be expecting rough running even at idle with gas gone bad. fuel filter partially blocked? |
Lo-Fi Version | Time is now: 27th August 2025 - 06:16 PM |
