> show me your hydraulic clutch setups
mb911
post Jul 14 2025, 04:04 PM
Looking for as many setups and insight for those that have done it. Parts list are much appreciated.
Chris914n6
post Jul 14 2025, 07:57 PM
Jackstands are my life.
which trans?
stock pedal or Tilton/Wilwood?
Subaru swap? LS swap? Ferrari swap?
East coaster
post Jul 14 2025, 08:30 PM
Here’s my setup. It’s for my Suby conversion, but should be viable for any setup. Don’t score my welds (IMG:style_emoticons/default/smile.gif)
post Jul 14 2025, 08:35 PM
http://www.914world.com/bbs2/index.php?showtopic=369256
Larry.Hubby
post Jul 14 2025, 09:16 PM
Member who doesn't post much, but has a long time in 914s
This thread talks about some of the hydraulic conversions people have done, including mine:
http://www.914world.com/bbs2/index.php?sho...c=90342&hl=
I have a 3.0 six with a 915 transmission in my car, but it's a '78 engine and trans, so I do have the over-center helper spring on the throwout mechanism at the transmission, and I added the helper spring down at the pedals as well to stay as close to stock as possible. The mechanical advantage can't be increased beyond stock without shortening the travel of the throwout lever, so I doubt you will get much relief from doing that before you run into inadequate clutch travel.
mb911
post Jul 15 2025, 04:55 AM
QUOTE(Chris914n6 @ Jul 14 2025, 05:57 PM) *
which trans?
Stock pedals stock transmission
post Jul 15 2025, 12:34 PM
@East coaster
You need to push the brake rod assembly onto the post and install the washer and cotter pin.
ClayPerrine
post Jul 15 2025, 03:59 PM
Here is how I did the clutch master setup:
(IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814683_thumb.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814691_thumb.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-1143-1555814703_thumb.jpg)
I reversed the shaft in the pedal box. That put the arm at the other end, so the clutch master doesn't have to mount to the front of the tunnel.
I ended up reworking the clutch master connection to the arm after driving it a bit. I changed it out for a clevis that went on both sides of the arm.
I ended up changing the master cylinder for a different one to get it to disengage the clutch completely, but now it is way too heavy. Rick918S found a 944 master cylinder that will work with a Boxster/Cayman slave, so I am going to give that a try.
East coaster
post Jul 15 2025, 04:53 PM
QUOTE(bdstone914 @ Jul 15 2025, 11:34 AM) *
@East coaster
Yup, it’s all together correctly in the car, this was just playing with the setup on my bench.
captain awesome
post Mar 23 2026, 09:31 AM
QUOTE(ClayPerrine @ Jul 15 2025, 04:59 PM) *
Any word on a master that works better? I installed a 5/8 Honda master with my Boxster 5 speed and have difficulty getting into gear. Pedal is super soft and pick up point is just off the floor. Looking into a 3/4 but I keep seeing mention that the effort is too high even though that's the Boxster size. Hoping you might have the answer before I start trying to chuck useless parts at it.
- Lo-Fi Version Time is now: 23rd March 2026 - 08:41 PM
