> Help with 6 heat exchanger mounting brackets
sixaddict
post Jun 14 2025, 09:10 AM
So finalizing engine details and need a little help with mounting brackets.
This picture shows mounting bracket in place.
The bracket on this side is MIA…maybe
Next is outboard…
Attached ImageAttached Image
Could some post what I should be seeing if correct. Zoom in on last pic and you can see outboard bracket. Trying to also determine where that attaches.
Thanks…..
post Jun 14 2025, 10:08 AM
I am not able to help with this, but it looks like things are coming together, keep it going
johnhora
post Jun 14 2025, 11:17 AM
TOT...don't think there's a mounting tab on that side..the one on the dr side has the tab that the clamp for attaching the speedo, clutch, and throttle cables is also connected
johnhora
post Jun 14 2025, 11:18 AM
here's another pic of OEM HE's
sixaddict
post Jun 14 2025, 12:22 PM
They are…..we ( builder and I) better known as technician and financier, plan to build engine stand as he would like to hear results of labors plus we can be sure all is well.
Thanks for noticing…
quote name='930cabman' date='Jun 14 2025, 08:08 AM' post='3210205']
[/quote]
sixaddict
post Jun 14 2025, 12:24 PM
John…
Thanks exactly what I was hoping for…..great pics!
Thank you.
Terry
fixer34
post Jun 14 2025, 01:33 PM
Yes, I believe the tab on the one side is to clamp the cables in place, not mount to the case.
On a different note, I see you installed turbo valve covers on the exhausts. If you ever plan to check/adjust the valves with the engine in the car (and bolted up) you need to mill/shave some of the fins around a couple bolts. Otherwise they won't clear the trailing arm frame mounts. There are a couple threads about it.
Ask me how I know..
post Jun 14 2025, 08:49 PM
Brackets..
porschetub
post Jun 14 2025, 09:57 PM
QUOTE(fixer34 @ Jun 15 2025, 07:33 AM) *
Ask me how I know..
(IMG:style_emoticons/default/agree.gif) why would want to solid mount to the HX on to the case ? but why it perfectly lines up on that case stub has got me baffled ??? .
Pretty sure OP knows about the lower rocker covers ,cheers.
porschetub
post Jun 14 2025, 10:42 PM
[quote name='porschetub' date='Jun 15 2025, 03:57 PM' post='3210274']
[quote name='fixer34' post='3210221' date='Jun 15 2025, 07:33 AM']
Ask me how I know..
[/quote]
Edit ,great pics supplied sixer ,confirms than bracket isn't there in that bunch of tressures you have ?? ,rest look like lower tin fitment ...think so as they are 6mm.
Cheers.
mb911
post Jun 15 2025, 04:34 AM
Terry are you still having the debate on the heat exchangers? Just one tab on that side and then the z bracket on the other side
sixaddict
post Jun 15 2025, 09:33 AM
QUOTE(mb911 @ Jun 15 2025, 02:34 AM) *
Yes kind of……..not sure I know what you mean on Z bracket….i see a bracket on outboard side and assume it must attach to something.
On valve covers ……will be changed before installing in the car…..but have a set of original look alikes ( SC) that are aluminum and purportedly won’t leak. (IMG:style_emoticons/default/dry.gif) vs magnesium originals. Now to find them.
mb911
post Jun 16 2025, 01:22 PM
QUOTE(sixnotfour @ Jun 14 2025, 06:49 PM) *
Brackets..
Terry z bracket is on the top in these pictures
sixaddict
post Jun 16 2025, 04:01 PM
Duh…
Now I get it. Thanks
porschetub
post Jun 16 2025, 06:46 PM
QUOTE(sixaddict @ Jun 16 2025, 03:33 AM) *
The mag ones on my motor were very warped ....some clown had installed 2 thick gaskets to stop the leaks then wound them up real tight (IMG:style_emoticons/default/slap.gif) .
Glued some sandpaper on to a sheet of thick glass and resurfaced then which took a lot, refitted them with beaded VR gaskets and they only lasted around 300 miles and started weeping, shortly after they started dripping .
Purchased a set 930 covers , checked them and both benefitted from a resurface but not a lot on one but the other required a fair bit of work , IMO the worst of the 2 would have leaked otherwise.
Cheers.
rgalla9146
post Jun 16 2025, 08:24 PM
The tab on the passenger box has two functions, it keeps the box from rattling
and provides attachment to keep the cables from drooping.
On the drivers side there is a small leg from the box to the forward exhaust stud
to keep the box from rattling, another bracket on the outside top surface is used with
a Norma hose clamp to keep the oil hose from contacting the heater box.
IT can be seen in 'six addicts' bottom three pics.
sixaddict
post Jun 18 2025, 02:54 PM
Sorry to belabor this but trying to determine where or what this one attaches to.
Circled in red.
Hoping this is final question.
Thanks
rgalla9146
post Jun 18 2025, 06:37 PM
QUOTE(sixaddict @ Jun 18 2025, 04:54 PM) *
Circled in red.
Thanks
Terry
Final answer. (IMG:style_emoticons/default/smile.gif)
That bracket is on the drivers HE on the top surface of the heater box.
It keeps the oil cooler hose from resting on the heater box. It works with a 30mm
clamp as pictured.
It's the hose that goes from oil cooler to oil tank.
fixer34
post Jun 18 2025, 06:51 PM
Installed picture..
sixaddict
post Jun 19 2025, 07:00 AM
(IMG:style_emoticons/default/piratenanner.gif)
- Lo-Fi Version Time is now: 1st July 2025 - 07:57 PM
