> FS 108 mm 4 bolt/2 pin 911 stub axles
racerx9146
post Jun 12 2025, 11:01 AM
good design never goes out of date..
Morning
This weeks garage clean-out special
108 mm 4 bolt/2 pin 911 stub axles for use with larger axles. $100 plus shipping from 95650 via USPS ground advantage. Paypal preferred. Please send a specific address so I can give you an accurate shipping quote before you pay.
I am including the outer hubs as well as you get the wheel studs. I don't think you can use them w/o machining or spacers as the bearing width is different or something. I forget.
regards Daron
Attached ImageAttached ImageAttached Image
Steve
post Jun 12 2025, 11:18 AM
These look like the early 72-73 stuff? I have these on my car. Spacers are only needed with the later hub centric setup. PMS sells the spacers.
post Jun 12 2025, 11:36 AM
I'm new here ...
QUOTE(racerx9146 @ Jun 12 2025, 12:01 PM) *
Morning
regards Daron
Do you have any pics off the stub axle shafts. The hubs look like the aer on backwards?
racerx9146
post Jun 12 2025, 12:26 PM
yes they are on backward for storage space!
Montreal914
post Jun 12 2025, 12:55 PM
pm sent.
post Jun 13 2025, 01:55 PM
I'm new here ...
Are they sold?
post Jun 13 2025, 02:02 PM
I'm new here ...
If not I’ll take them
Montreal914
post Jun 13 2025, 03:47 PM
Looks like there is a line (IMG:style_emoticons/default/smile.gif)
post Jun 17 2025, 02:38 PM
I'm new here ...
Any update?
- Lo-Fi Version Time is now: 1st July 2025 - 09:16 PM
