> Charge Question
Halfnelson
post Jun 9 2025, 11:09 AM
Region Association: England
Quick question - if I'm going to either trickle charge or charge the battery in-situ, should I disconnect the battery leads first. Don't want to damage anything during the charge process.
Geezer914
post Jun 9 2025, 11:23 AM
Geezer914
Yes, disconnect the battery cable leads to isolate the battery.
Halfnelson
post Jun 10 2025, 01:33 AM
Thanks Geezer914
Dave_Darling
post Jun 10 2025, 05:12 AM
914 Idiot
Just the ground is good enough.
--DD
Steve
post Jun 12 2025, 09:54 AM
I never removed anything with my trickle charger and never had a problem, but I did this with my stock 3.2 and now my 3.6. What problems have you run into?
My v8 914 is also setup this way with no problems so far…
Over 20 years connected this way…
infraredcalvin
post Jun 12 2025, 12:21 PM
Distracted Member
QUOTE(Steve @ Jun 12 2025, 08:54 AM) *
Some of the trickle chargers come with a quick connect that you 'permanently' wire to the battery leads, so you're not messing with the alligator clips popping off and grounding on something it shouldn't. makes storage and trickle charging easy...
Steve
post Jun 12 2025, 12:30 PM
QUOTE(infraredcalvin @ Jun 12 2025, 11:21 AM) *
On one of my cars i rewired the cigarette lighter directly to the battery. I plug in the trickle charger there when the car is not in use. On my other 914 it has a plug on the battery. I plug it in when I know I will not be driving the car for awhile.
- Lo-Fi Version Time is now: 7th December 2025 - 01:36 PM
