| FlacaProductions |
Jun 7 2025, 09:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,132 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I guess file this under general garage skill but Porsche-related.
67 911 and I canNOT get this split nut off to remove/rekey the glovebox lock. Pic stolen from the internet as it best shows the nut in question. I just can't find anything that will get enough "bite" Asking here rather than other 911-centric boards since we're a bit more "hands-on"... Thanks! Brian ![]() |
Jun 7 2025, 09:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,651 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The first tool I would grab is an adjustable pin spanner
Attached thumbnail(s) |
| 914Sixer |
Jun 7 2025, 10:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,396 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Did you take the snap ring off?
| DennisV |
Jun 7 2025, 11:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 844 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I guess file this under general garage skill but Porsche-related. 67 911 and I canNOT get this split nut off to remove/rekey the glovebox lock. They make what is called a locknut socket. There are many different sizes and depths. The linked one is probably not the right one for your application, just an example. I did a basic 3D design and printed it to get the one off our 914-6 glove box. (IMG:style_emoticons/default/smash.gif) |
| barefoot |
Jun 7 2025, 11:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
I took a nickel & notched it out to the desired shape, this just grabs 2 not 4 lugs however.
(IMG:style_emoticons/default/biggrin.gif) |
| FlacaProductions |
Jun 7 2025, 11:20 AM
Did you take the snap ring off? Ooooh. This may be the key. I now see what you see in that pic - but I'll have to see if that's reality for my particular situation. Haven't noticed a snap ring but I'll check. Good one. Otherwise - great suggestions on new tools to buy!! (love this board) |
| L-Jet914 |
Jun 7 2025, 11:46 PM
Member ![]() ![]() Group: Members Posts: 377 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I guess file this under general garage skill but Porsche-related. 67 911 and I canNOT get this split nut off to remove/rekey the glovebox lock. Pic stolen from the internet as it best shows the nut in question. I just can't find anything that will get enough "bite" Asking here rather than other 911-centric boards since we're a bit more "hands-on"... Thanks! Brian ![]() That looks like an antenna nut (the 4 slotted nut yes?). Try purchased an antenna nut removal socket or wrench. |
| FlacaProductions |
Jun 8 2025, 08:07 AM
ooh. never heard of an antenna nut tool - but I see them now. thank you!
| L-Jet914 |
Jun 9 2025, 09:14 PM
| TheCabinetmaker |
Jun 10 2025, 07:08 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,360 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The snap ring does not facilitate removing the nut and lock tab. It just holds the lock cylinder in place. I've removed literally hundreds of them with just a straight screwdriver.
| Jamie |
Jun 10 2025, 07:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
The snap ring does not facilitate removing the nut and lock tab. It just holds the lock cylinder in place. I've removed literally hundreds of them with just a straight screwdriver. Long nosed pliers usual will fit into the opposite slots to remove or install. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 24th January 2026 - 11:14 PM |
