SteveNMaine |
Newbie ![]() Group: Members Posts: 43 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None ![]() |
I am looking at the Bursch exhaust for my 2056 and need some guidance.
The Bursch BX.1404.SS combines cyls 2&4 and 1&3 crossing over from one side of the engine to the other. The Bursch BX.1402.SS combines cyls 1&2 and 3&4 crossing over the pipes on just the same side. What is the difference in performance? |
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 859 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
I am looking at the Bursch exhaust for my 2056 and need some guidance. The Bursch BX.1404.SS combines cyls 2&4 and 1&3 crossing over from one side of the engine to the other. The Bursch BX.1402.SS combines cyls 1&2 and 3&4 crossing over the pipes on just the same side. What is the difference in performance? I don't think you will feel a difference. Free flow in better. Matt |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,227 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The firing order is 1-4-3-2 so both of those exhausts should work about the same.
(IMG:style_emoticons/default/idea.gif) |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,692 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Decent explanation of headers:
https://www.youtube.com/watch?v=puAACxYP_dw Believe the T1 shares the same firing order as a T4. |
Nogoodwithusernames |
Member ![]() ![]() Group: Members Posts: 289 Joined: 31-May 16 From: Sutter, CA Member No.: 20,051 Region Association: None ![]() |
The part numbers posted look to me like two parts in the same system and both are needed unless you're using your existing heat exchangers.
https://lnengineering.com/bursch-bx-1404-ss...ust-system.html https://lnengineering.com/bursch-bx-1402-ss...eel-header.html As far as which cylinders to merge you want 1-3 and 2-4 grouped so that pulses are 180° out from each other. Doesn't matter in a 4:1 system but in a 4:2:1 or 4:2 it will. |
Lo-Fi Version | Time is now: 1st June 2025 - 11:37 AM |
